1940
ViewState is corrupted.
I have 2 pages, both load their controls dynamically.
each page loads a few controls, one of these controls contains a WebDataGrid bound to test data, setting DataSource to a manually filled list.
Those 2 controls with WebDataGrid are not the same control, but they are actually technically equal.
At Page 1 everyhting works fine.
At Page 2 any time a postback occurs I get the following exception:
Infragistics.Web.UI.GridControls.Behaviors ViewState is corrupted.
   bei Infragistics.Web.UI.Framework.ObjectCollection.LoadViewStateItems(ArrayList itemList)
   bei Infragistics.Web.UI.Framework.ObjectCollection.LoadViewState(Object savedState)
   bei Infragistics.Web.UI.Framework.ObjectCollection.System.Web.UI.IStateManager.LoadViewState(Object savedState)
   bei Infragistics.Web.UI.GridControls.WebDataGrid.LoadViewState(Object savedState)
   bei System.Web.UI.Control.LoadViewStateRecursive(Object savedState)
   bei System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState)
   bei System.Web.UI.Control.AddedControl(Control control, Int32 index)
   bei System.Web.UI.ControlCollection.Add(Control child)
   bei Binner.ProjectManager.GraphicalUserInterface.Classes.ContentPage.LoadPageControls(BaseElement baseElement) in N:\ProjectManager\Binner.ProjectManager.GraphicalUserInterface\Classes\ContentPage.cs:Zeile 170.
   bei Binner.ProjectManager.GraphicalUserInterface.Classes.ContentPage.OnLoad(EventArgs e) in N:\ProjectManager\Binner.ProjectManager.GraphicalUserInterface\Classes\ContentPage.cs:Zeile 47.
   bei Binner.ProjectManager.GraphicalUserInterface.Pages.Workplace.Dependencies.OnLoad(EventArgs e) in N:\ProjectManager\Binner.ProjectManager.GraphicalUserInterface\Pages\Workplace\Dependencies.aspx.cs:Zeile 40.
   bei System.Web.UI.Control.LoadRecursive()
   bei System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
nothing special in the aspx:
Part of Page 1:
    <tr>
        <td colspan="3">
            <igmisc:WebPanel ID="WebPanel1" runat="server" SkinID="ContentWebPanel" Header-Text="<%$ Resources:Lang, WorkplaceRecordsControl_recordRegistrationWebPanel %>"
                Header-TextAlignment="Left">
                <Header Text="WorkplaceRecordsControl_recordRegistrationWebPanel" TextAlignment="Left">
                </Header>
                <Template>
                    <ig:WebDataGrid ID="recordRegistrationDataGrid" runat="server" SkinID="WebDataGrid" AutoGenerateColumns="False">
                        <Columns>
                            <ig:BoundDataField DataFieldName="Date" Key="Date">
                                <Header Text="Date" />
                            </ig:BoundDataField>
                            <ig:BoundDataField DataFieldName="Duration" Key="Duration">
                                <Header Text="Duration" />
                            <ig:BoundDataField DataFieldName="Description" Key="Description">
                                <Header Text="Description" />
                        </Columns>
                    </ig:WebDataGrid>
                </Template>
            </igmisc:WebPanel>
        </td>
    </tr>
Part of Page 2 (Erroring):
        <tr>
            <td colspan="3">
                <ig:WebDataGrid ID="webDataGridProjectDependencies" runat="server"
                    <Columns>
                        <ig:BoundDataField DataFieldName="Predecessor" Key="Predecessor">
                            <Header Text="Predecessor" />
                        <ig:BoundDataField DataFieldName="PSP" Key="PSP">
                            <Header Text="PSP" />
                        <ig:BoundDataField DataFieldName="RelationType" Key="RelationType">
                            <Header Text="RelationType" />
                        <ig:BoundDataField DataFieldName="Offset" Key="Offset">
                            <Header Text="Offset" />
                    </Columns>
                </ig:WebDataGrid>
            </td>
        </tr>
The exception occurs right after I add another control into the control with Controls.AddAt(0, control) int he OnInit() override. (removing this does not help)
So I suspect while trying to load ViewState in LoadViewState() (not overridden) the exception is thrown.
(setting "EnableViewState" = "Disabled", of course, fixed this exception, but not my problem :-))
I am using Volume 2010.3.2134
Need help!
Carsten
