8736
Multiple band with manual load on Demand Sample
Hello All,
The attached sample  demonstrates how to populate multiple band using manual load on demand. Due to size restriction ig_res folder is removed. You may add this at your end.
Hope this helps.
Bhadresh
WebHierachicahlMultipleband_VB.zip
  • 935
    Hi Sir Can you send me an example how to use multiple band  on load demand in c# .
    In My Code I need to populate third level of my WHDG.
    protected void WebHierarchicalDataGrid_RowIslandsPopulating(object sender, ContainerRowCancelEventArgs e)
                //Cancel the default automatic load on demand operation
                e.Cancel = true;
                // Get the data key
                int key = (int)e.Row.DataKey[0];
                _itemClass.MyItemReqId = key;
                var first = _itemClass.MyItemReqDetailQByItemReqIdRead(); //Datatable
                // Create Container Grid
                ContainerGrid childGrid = new ContainerGrid();
                childGrid.InitializeRow += Child_InitializeeRow;
                e.Row.RowIslands.Add(childGrid);
                // Bind Grid
                childGrid.DataSource = first;
                childGrid.DataBind();
     IN this area i need to get the key from  the firstchild i used to follow your example in vb but i always get an error.
                    _itemClass.MyItemReqDetailId = (int)e.Row.RowIslands[0].Rows[0].DataKey[0];
                    var second = _itemClass.MyErploctransByItemReqDetailIdRead();
                    ContainerGrid child1 = new ContainerGrid();
                    child1.InitializeRow += Child1_InitializeeRow;
                    e.Row.RowIslands[0].Rows[0].RowIslands.Add(child1);
                    child1.DataSource = second;
                    child1.DataBind();
