We are using the control to display a set of ten pictures relevant to an event, when we mae a change on the pictures (replace a picture with another with the same name), the new picture is not showig in the control, the control keeps the ol one, we have to close the navigator an open it again to have the pictures refreshe, is there some way to fix it?
thank you
Hi losoriomx,
It has been some time since your post, however in case you still need assistance I would be happy to help.
I am not certain I full understand your setup, but if you are storing your 10 pictures in a datasource I would suggest that you ensure that the data is saved in the datasource before calling the WebImageViewer's DataBind() method. Should the change be happening on the client I would suggest that you take a look at this article:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.2/CLR4.0/html/WebImageViewer_Adding_Images_to_the_WebImageViewer_on_the_Clientside.html
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
