40
webdatatree databinding with dataset
I am new to webdatatree. I wrote the fallowing code to bind the webdatatree.
Here my datasource is normal dataset which has multiple tables with proper relations.
But I am unable to bind to webdatatree.Is there something wrong with my code?
 UWT_Departments.DataSource = dsetMenuNodes;
for (int iCount = 0; iCount < dsetMenuNodes.Tables.Count; iCount++)
                     DataTreeNodeBinding db = new DataTreeNodeBinding();
                     db.DataMember = dsetMenuNodes.Tables[iCount].TableName;
                     db.TextField = "vGroup_Name";
                     db.ValueField = "intGroup";
                     UWT_Departments.DataBindings.Add(db);
                 UWT_Departments.DataBind();
Do I need to use WebHierarchicalDataSource to bind webdatatree? If So can you give an example to convert normal dataset to WebHierarchicalDataSource.
  • 5105
    Suggested Answer
    Hi there,
    Please don't forget to set primary keys for the tables in your dataset. Once you do this your issue should go away :)
    Thank you for using the Infragistics forums!
