935
How to Get WebDatamenuItem ID and to show fancy box iframe
WebDataMenu:
<ig:WebDataMenu ID="WebDataMenu1" runat="server" Width="100%" Height="30%">
                <Items>
                  <ig:DataMenuItem NavigateUrl="Default.aspx" Text="Home" Value="0">
                  </ig:DataMenuItem>
                   <ig:DataMenuItem Text="Transactions" Value="0">
                       <Items>
                           <ig:DataMenuItem NavigateUrl="../Forms/Issue.aspx" Text="Issue/Return"
                               Key="Issue">
                           </ig:DataMenuItem>
                           <ig:DataMenuItem IsSeparator="True" Text="[Separator]">
                           </ig:DataMenuItem>
                           <ig:DataMenuItem NavigateUrl="../Forms/Request.aspx" Text="Request"
                               Key="Return">
                           </ig:DataMenuItem>
                       </Items>
                  </ig:DataMenuItem>
              </Items>
                       <GroupSettings Orientation="Horizontal" EnableAnimation="False" />
              </ig:WebDataMenu>
Example:
if i click Issue DataMenu Item,fancy Box will Display.
Thanks in Regards
  • 49378
    Hi NewbApps,
    It has been some time since your post, however in case you still need assistance I would be glad to help.
    You can handle the ItemClick client-side event to set the src of your iframe if the clicked item is the desired one. For instance:
    function WebDataMenu1_ItemClick(sender, eventArgs)
    if (eventArgs.getItem().get_key() == "iframeItem") {
            document.getElementById(
    "iframe1").src = "Default2.aspx";
    Please do not hesitate to contact me if you have any questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
