Hi.
I have a WebDate grid with two types of EditorProvides (DatePickerProvider and DropDownProvider). Everything works perfectly fine when I run my applicaiton on my local machine but once I copy over my application to the web server the providers do not work. the WebDataGrid binds fine, I see all the data Ineed to see but when I click on the cell to edit the EditorProvider does not show. I see the drop down arrow in the cell to click for the calendar/dropdown but the page just flashes and no calendar or dropdown show. I put this WebdataGrid in its own updatepanel. the aspx page also has a formview, SQL data Sources, script manager...code for gird is below. again works fine on local machine but not on webserver. please help! :(
<asp:UpdatePanel ID="UpdatePanel2" runat="server">
<ContentTemplate>
<ig:WebDataGrid ID="wdgSubDates" runat="server" Height="180px" Width="900px" AutoGenerateColumns="False"
DataSourceID="dsSubDate" DataKeyFields="ocd_control_number,ocd_submission"
EnableDataViewState="True" >
<Columns>
<ig:BoundDataField DataFieldName="ocd_control_number" Hidden="True"
Key="ocd_control_number" DataType="System.Double">
<Header Text="ocd_control_number" />
</ig:BoundDataField>
<ig:BoundDataField DataFieldName="ocd_submission" Key="ocd_submission"
Width="100px">
<Header Text="Submission #" Tooltip="Submission #" />
<ig:BoundDataField DataFieldName="ocd_doc_date" Key="ocd_doc_date"
Width="150px">
<Header Text="Document Date" Tooltip="Document Date" />
<ig:BoundDataField DataFieldName="ocd_received_date" Key="ocd_received_date"
<Header Text="Received Date" Tooltip="Received Date" />
<ig:BoundDataField DataFieldName="ocd_due_date" Key="ocd_due_date"
<Header Text="Due Date" Tooltip="Due Date" />
<ig:BoundDataField DataFieldName="ocd_completion_code"
Key="ocd_completion_code" Width="200px">
<Header Text="Action" Tooltip="Action" />
</Columns>
<EditorProviders>
<ig:DatePickerProvider ID="DatePickerProvider1" >
<EditorControl ID="EditorControl1" DisplayModeFormat="MM/dd/yyyy"
EditModeFormat="MM/dd/yyyy" runat="server" >
</EditorControl>
</ig:DatePickerProvider>
<ig:DropDownProvider ID="DropDownProvider1">
<EditorControl EnableAnimations="False" runat="server"
EnableDropDownAsChild="False" ID="EditorControl2" Width ="140px"
DropDownContainerWidth = "140px" DropDownContainerHeight="0px" >
<Button AltText="" />
<Items>
<ig:DropDownItem Selected="False" Text="Approved" Value="Approved">
</ig:DropDownItem>
<ig:DropDownItem Selected="False" Text="Disapproved" Value="Disapproved">
<ig:DropDownItem Selected="False" Text="Withdrawn" Value="Withdrawn">
<ig:DropDownItem Selected="False" Text="Revise & Resubmit"
Value="Revise & Resubmit">
</Items>
</ig:DropDownProvider>
</EditorProviders>
<Behaviors>
<ig:EditingCore AutoCRUD="false">
<ig:CellEditing>
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="ocd_doc_date"
EditorID="DatePickerProvider1" />
<ig:EditingColumnSetting ColumnKey="ocd_received_date"
<ig:EditingColumnSetting ColumnKey="ocd_due_date"
<ig:EditingColumnSetting ColumnKey="ocd_completion_code"
EditorID="DropDownProvider1" />
</ColumnSettings>
<EditModeActions MouseClick="Single" />
</ig:CellEditing>
<ig:RowAdding>
<ig:RowAddingColumnSetting ColumnKey="ocd_doc_date"
<ig:RowAddingColumnSetting ColumnKey="ocd_received_date"
<ig:RowAddingColumnSetting ColumnKey="ocd_due_date"
<ig:RowAddingColumnSetting ColumnKey="ocd_completion_code"
<ig:RowAddingColumnSetting ColumnKey="ocd_submission" ReadOnly="True" />
</ig:RowAdding>
<ig:RowDeleting />
</Behaviors>
<EditingClientEvents RowAdding="onRowAdding" />
</ig:EditingCore>
<ig:Selection CellClickAction="Row" RowSelectType="Single">
<SelectionClientEvents RowSelectionChanged="onRowSelectionChanged" />
</ig:Selection>
<ig:RowSelectors>
</ig:RowSelectors>
<ig:Filtering>
</ig:Filtering>
</ig:WebDataGrid>
</ContentTemplate>
</asp:UpdatePanel>
So far it seems like it has to do with using a MasterPage on the aspx page.
When I add a grid with a editor provider on a page that has a masterpage it does not work. but add a grid to a page that does not use a MasterPage it works???
any ideas?
