260
Presets don't work for WebMonthView
This is a problem I have been dealing with for literally years.  On every PC I've installed Infragistics on, I have been unable to use presets for the calendar and have had to settle for using the default yellow.
My current PC:  Running Windows Vista with 3 Hard Drives.  C: System files, D: Development (including Infragistics and VS 2005), E: Games.
On my system I have 2007.1, 2007.3, and I just re-installed 2008.1.  None of the WebMonthView controls show the presets during design time, nor do they work at runtime.  Just before I reinstalled 2008.1, I was able to see the control rendering when I ran it in VS2005.  Now, after the reinstall, I don't see anything in design or runtime.  I even tried adding the image redirect in the web.config file and that didn't work either.
Has anyone had this problem?  Found a fix?  Anyone know what is going on?
Justin
  • 28
    Hi All,
     I'm just getting started with infragistix, and it seems that I have the same Problem as tolchinj. None of the presets will work on the WebCaledarView...
     Are there any good ideas or fixes?
     Thanks arne
    edit:  Seems like the path in the XML-file is totally wrong; how can this happen if it is a completly new installation???
    edit: My Fault --> havn't thought about the virtual directory ( http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=10115 )
