i have a usercontrol and inside the UserControl i have a WebDataGrid.
WebDataGrid. WebDataGrid is exist inside the UpdatePanel.
i have kept the UserControl in a form, and form is inharited from a Master Control,
At my master form, i have kept ContentPanel inside a UpdatePanel.
when i select the row then Grid ClientSide RowSelection ClientSide event occur,
at clientSide event i am trying PostBack the form to do some thing,
but this event give me script error, i have seen script internal error, it is giving me
Input string was not in correct format error.
clisde side PostBack code:
function OnRowSelectionChnaged(sender, eventArgs) { __doPostBack('<%=gridUpdatePanel.ClientID%>'); }
Detail error was
System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at System.String.System.IConvertible.ToInt32(IFormatProvider provider) at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider) at System.Convert.ChangeType(Object value, Type conversionType) at Infragistics.Web.UI.Framework.Data.DataBot.ChangeType(Object value, Type toType) at Infragistics.Web.UI.Framework.Data.DataBot.Compare(Object value1, Object value2) at Infragistics.Web.UI.GridControls.GridRecordCollection.FromKey(Object[] dataKey) at Infragistics.Web.UI.GridControls.GridRecordCollection.FromIDPair(IDPair idPair) at Infragistics.Web.UI.GridControls.SelectedRowCollection.ResolveItemFromIDPair(Dictionary`2 idPair) at Infragistics.Web.UI.GridControls.GridIDPairCollection`1.get_Item(Int32 index) at Infragistics.Web.UI.GridControls.GridIDPairCollection`1.Enumerator`1.get_Current() at Infragistics.Web.UI.GridControls.Selection.BehaviorEvents_PreRender(Object sender) at Infragistics.Web.UI.GridControls.GridBehaviorEvents.RenderingContentHandler.Invoke(Object sender) at Infragistics.Web.UI.GridControls.GridBehaviorEvents.OnRenderingContent() at Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) at Infragistics.Web.UI.Framework.RunBot.HandleRenderContents(HtmlTextWriter writer, RendererBase renderer) at Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.RenderContents(HtmlTextWriter writer) at Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.HtmlControls.HtmlTableRow.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.HtmlControls.HtmlTable.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.UpdatePanel.RenderChildren(HtmlTextWriter writer) at System.Web.UI.UpdatePanel.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.PageRequestManager.RenderFormCallback(HtmlTextWriter writer, Control containerControl) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) at System.Web.UI.HtmlFormWrapper.System.Web.UI.IHtmlForm.RenderControl(HtmlTextWriter writer) at System.Web.UI.PageRequestManager.RenderPageCallback(HtmlTextWriter writer, Control pageControl) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Page.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
How can i resolve this error?
I have the same issue. Mine occurs when I insert a new row in back mode, manual crud, and then edit the greyed out row columns.
in my webform WebDataGrid and WebExplorerBar and WebDropdown all are on same page.
First select an item from a explorerbar item list, and then select a row from webdatagrid.
now error will come. check it.
I am still in that issue, i am still waiting for your answer.
please help me to resolve the issue.
i did as u suggest, but still have same problem.
i have set the autopostback true and removed _doPostback code
from client, but still have same problem.
i know its related to row selection issue.
i did too much R&D but still getting the error, can u give me any clew?
Hi MyPost,
Do you still get this error if you use RowSelectionChanged autopostback flag set to true and the enable ajax property of the grid set to false? So take the __doPostback code out of your client row selection changed event handler.
regards,David Young
