I recently upgraded to 2011 Volume 1 and now NONE of my WebDataMenu's work.
I added the new Upload control, but as soon as I add the script reference to ig.ui.min.js, it kills my WebDataMenu's.
When I click on a node on my main menu, I get:
Microsoft JScript runtime error: Object doesn't support this property or method on the line var level = item.get_level(); in __hideUpLevelItems: function(currentItem).
When I use the showAt method to bring up my context menu I get Microsoft JScript runtime error: Object doesn't support this property or method on the line item.__clearAnimation(false) in __hideItemElement: function(item).
Another stellar job of testing by Infragistics before realeasing a new version!!!
Back to 2010 Volume 3 for me. Then on to Telerik controls once out contract is over with IG.
Hi Tsvetelina,
Its sorted out after getting 11.2 version!!!
SAM
Hello Sam,
Have you installed the latest service release
Build 11.1.20111.2135
Hope hearing from you.
Is this issue sorted out?? I am still not able to use showAt with the WebMenu.
Sam
I am also facing this problem of ShowAt method not supported. I tried your workaround, but no success. I am unable to download the service release also. In a total fix!!
Hello RBonser ,
I created a new support ticket on your behalf regarding this.
I will contact you through the case CAS-68918-R82X19.
