Hej!
Thank you for the good work on the controls.
I use a dynamically created WHDG and I want to set the width of a column in the very first grid band (=the WHDG itself). I do that by setting the width property of the columns in my Grids' Column Collection (in PreRender Event). The width style is rendered into the row itself in the html and everything is fine:
<td style="width: 20px;" adr="0" idx="0" type="cell">
When Filtering behavior is activated (created and added just before OnLoad), this does not work. No width is added to the row anymore. Do you have any suggestions what could be done to get the width set?
Thank you for your help,
tidad
Sorry, it is not the Filtering, it is the Sorting Behaviour which has the described effect.
We use Version 10.3.20103.1013
Is this Issue maybe adressed in a latter version?
