is it possibile to create a bar chart where Y-axis is displayed in the middle of X-axis and coordinates are moved? Bars would be then displayed not from left to right, but from the middle to left or right depeding on their values. Something like this:
I would also need something very similiar for column chart.
Bartek
Hi Guys,
The answer to that problem i asked at the begining is here:
http://forums.infragistics.com/forums/p/60574/307885.aspx#307885
You need to set axis.x.rangemax and rangemin to opsite values and rangetype as custom
Cheers
Can i move the Y-axis to the right side of the chart programatically?
Hello Bartek,
Let me know if you have further questions.
You can use the “Chart Wizard” from the chart “Smart Tag” to specify the position of the X and Y-axis.
When you open the wizard you should select “Bar Chart”, go to step 3 (Axes) and from “Axes Extent and Margins” tab use the visual designer to specify the look and position of the X and Y-axis.
Let me know if you have any additional questions.
