80
ToolTip on Webtab header
My tooltip only appears on tab content. Is it possible to set a tooltip on tab header like on content?
My ascx:
<ig:WebTab ID="wTab" runat="server" Width="100%" CssClasses-CssClass="InfragisticsTabStyle" StyleSetName="ESC" Font-Names="Arial,Helvetica,sans-serif" Font-Size="Small" OnSelectedIndexChanged="wTab_SelectedIndexChanged" AutoPostBackFlags-SelectedIndexChanged="On" BackColor="#F2F2F2">
                    <AutoPostBackFlags SelectedIndexChanged="On" />
                    <Tabs>
                        <ig:ContentTabItem runat="server" Text="Tab1" Width="250px" BackColor="#F2F2F2" ImageAlignment="Leading">
                            <Template>
                                <table class="InfragisticsTabStyle">
                                    <tr>
                                        <td>...
My ascx.cs:
ContentTabItem tabChol = wTab.Tabs[0];
wTab.ToolTip = "tooltipText";
Thanks a lot!
  • 24497
    Thank you for a report.
    The ToolTip (title attribute) was rendered by WebControl which is the base class of TabItem. That feature of base class was missed by logic of WebTab.
    The ToolTip should appear in tab-label. I tested following and it worked as expected:
    <ig:WebTab ID="WebTab1" runat="server" Height="200px" Width="300px">
        <Tabs>
         <ig:ContentTabItem runat="server" Text="Tab 1" ToolTip="tooltip">
         </ig:ContentTabItem>
         <ig:ContentTabItem runat="server" Text="Tab 2">
        </Tabs>
    </ig:WebTab>
    That issue has been fixed and TabItem.ToolTip will appear only in label of tab item.
    Update should be available in a month or 2 within coming service releases.
