I am using the WebDropDown control v11.1, and I`ve set the following properties:
AutoFilterQueryType : ContainsAutoPostBack : FalseAutoPostBackFlags - SelectionChanged : OnAutoPostBackFlags - ValueChanged : OffAutoSelectOnMatch : FalseEnableAutoFiltering : ClientStyleSetName : RedPlanetWidth : 200px
All the other properties are set to default.
This is my problem: When I select an item from the list, I can for example set a Label to the selecteditem.text value (in the WebDropDown1_SelectionChanged event handler).
But after selecting a value, (and the the postback) when I edit the value in the WebDropDown to trigger the autofiltering, then the WebDropDown immediately performs a postback (on the moment of editing the text)! and in the WebDropDown1_SelectionChanged eventhandler, I get the a NullReferenceException (object reference not set blah blah) on reading the value of the SelectedItem (cause there is no selected item, i know)...
But please tell me, why does the WebDropDown perform a postback?? This is how to reproduce it:
- Create a ASP.NET 4 WebAplication- Drag a WebDropDown and a label on the form- Set the properties as shown above- In de Page_Load: add a few items to the webdropdown- In the SelectionChanged Eventhandler of the webdropdown, set the Text property of the label to the SelectedValue.Text property of the WebDropDown- Build and Run the app- Select an item from the dropdown- See how the label`s text changes- AND NOW: edit the text in the DropDown (you should expect the autofiltering is triggered) and like you can see, the DropDown performs a postback without a selectedvalue... why why why???
please help me...? :)
thanks a lot!
set the clientside selectionchanging event to the following javascript to solve this:
function selectionchanging(sender, args) { if (!sender._activeItem) { args._cancel = true; }}
Regards,Klaas Polinder
Thank you very much, Rado! Looking forward to a solution.
Hi Rado,
Thanks a lot! That`s a quick follow up :)
I'll wait for a solution from your development team, thanks in advance :)
Hello Andre,
I have created support ticket on your behalf with number : { CAS-69580-MXQZKK } which can be referenced under you account on the followin link : https://ko.infragistics.com/Membership/MySupport.aspx
I will update you through the ticket about the progress of the Development issue that I have created.
Hello drewijnholds,
I would like to inform you that I was able to reproduce this control behavior. It doesn't seem to be correct. I will follow-up with you shortly.
