935
How to Add CheckBox Template Field on ChildBand in Server Side Code?
I am using Manual On Load Demand to Bind child grid in my WHDG.
This is My Code:
 protected void WebHierarchicalDataGrid1_RowIslandsPopulating(object sender, ContainerRowCancelEventArgs e)
//Cancel the default automatic load on demand operation
            e.Cancel = true;
            // Get the data key
            int key = (int)e.Row.DataKey[0];
            _item.DetailId = key;
            var p = itemRead();
             // Create Container Grid
            ContainerGrid childGrid = new ContainerGrid();
            childGrid.InitializeRow += Child_InitializeeRow;
            e.Row.RowIslands.Add(childGrid);
            // Bind Grid
            childGrid.DataSource = p;
            childGrid.DataBind();
  private bool isChild;
   protected void Child_InitializeeRow(object sender, RowEventArgs e)
            isChild = true;
            var gridRecord = (ContainerGridRecord)e.Row;
            if (gridRecord.Items.Count == 0)
                return;
            // Sets theItem Column
            var columnItemID = (BoundDataField)gridRecord.Items[0].Column;
            columnItemID.Width = 200;
            columnItemID.Header.Text = "ItemID";
                 In this Area i need to insert a check box which will be the last column
I got this code from the other thread but i don't know how to use it yet:
     public class ActionChildItemTemplate : ITemplate
            #region ITemplate Member
            public void InstantiateIn(Control container)
                CheckBox chk = new CheckBox();
                chk.ID = "chk";
                container.Controls.Add(chk);
            #endregion
After that  i need to loop the child band that is checked by the user and reference the key from parent row.
Thanks in Regards
  • 49378
    Verified Answer
    Hi NewbApps,
    It has been some time since your post, however in case you still need assistance I would be glad to help.
    You should be able to add a templated column to your container grid inside the RowIslandsPopulating handler using something similar to:
                TemplateDataField col = new TemplateDataField();
                col.ItemTemplate = new ActionChildItemTemplate();
                col.Key = "tempCol";
                if (child.Columns.FromKey("tempCol") == null)
                    child.Columns.Add(col);
    where child is the container grid element.
    Please feel free to contact me if you have any questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
