Ok, so I have a WHDG bound to a dataset. I do not want the Primary Key column to be shown in the first band. I set the hidden bouddatafield property of that column to true and now the second band does not appear. So how do I hide the column I use as a primery key without breaking the control's behavior?
Hi Javier,
Glad that your issue is resolved. Please contact me if I can be of further assistance.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Hi Petar,
Thanxs for replying. I cannot reproduce the error again. I have hidden the field that binds the primary band with the secondary one and the control is still working. I don't know what I was doing that the control broke that time.
Sorry!
Javier
Hi jwquiroz,
Please do not hesitate to contact me if you are still experiencing issues.
Best Regards,
I have investigated your scenario but was unable to replicate the issue you describe. I am attaching a sample with a WebHierarchicalGrid where the Primary Key column of the root band is hidden.
In order to investigate this matter further I would need more information about your grid setup and the conditions under which the issue is reproducible.
