485
Center text in WebDropDown
I'm testing WebDropDOwn. ¿How can i center the text?. I've tried adding a webtexteditor but when i press a key i get the error : 'keyCode' is null or not object
  • 49378
    Hi antfor,
    You can center the text in a WebDropDown using CSS. The file ig_dropDown located in the ig_res/Default directory of your project contains the styling settings for the WebDropDown. The classes which will most likely interest you are  .igdd_ValueDisplay for the input field and .igdd_DropDownList for the drop down list of items.
    I have created a sample for you which demonstrates a WebDropDown with centered text. The CSS styling in the sample is added through the markup.
    Please tell me if this helps.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
    WebDropDownCenterText.zip
