I have written a asp.net page that uses javascript to determine if an item in the dropdown isSelected or not. When I use the mouse to open the drop down and select an item everything works ok. However when I use tab and arrow down/up, when it gets the .isSelected it comes back as false.
What do I need to set to get that to reconize that it was selected?
please check it out
http://ko.infragistics.com/community/forums/t/80992.aspx
Pradeep
Hi
I am facing the same problem when i try to select an item using the arrow and tab key in igCombo. where as on press of Enter key the text are changing in the Dropdown.
Is there any solution for it.
Hi apalcer,
I am following up to check whether you are still experiencing any issues. Please do not hesitate to contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Thank you for pointing out this issue to us.
I have created a support ticket with case number CAS-70543-9LL3FD for your case, which you can monitor by going to the “My IG” tab on our website, and selecting "My Support Activity" from the drop-down.
https://ko.infragistics.com/Membership/MySupport.aspx
I have investigated the scenario you have described and after being able to reproduce the issue I have asked our engineering staff to examine this further. To ensure that it will receive attention, the behavior has been logged in our system with a Development ID of 84549. The next step would be for a developer to examine and review my investigation.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any time.
In the meantime I can offer you a possible alternative approach for achieving the same functionality without using the isSelected() method. You can get the value of the selected item which is always returned correctly. Hence, you can check if some item is checked by comparing its value to the value of the currently selected item.
You could access the value of a particular item using:
$find('WebDropDown1').get_items(0).get_value()
The value of the currently selected item can be acquired by something like:
$find('WebDropDown1').get_selectedItems().get_value()
Please let me know if this helps.
