is it possible to use an ASP.NET WebDataTree within an MVC view with Razor syntax?
I have come with a few issues trying to do this and would like to know if it is possible at all.
First problem is the IGMvcScriptManager's assembly has the same name and identity as the MVC assembly.
Second problem is when rendering the WebDataTree, ASP.NET's engine thinks it is design time and leaves some internal objects null (Infragistics.Web.UI.Framework.AppStyling.StyleBot.AppStylingManager, see http://forums.infragistics.com/forums/p/55715/299039.aspx#299039)
Thanks for your help.
regards.
jbergenthal
Hello jbergenthal,
Thank you for posting in our forums.
WebDataTree is not supported in MVC view.
I strongly recommend you wating for the next release 11.2 of jQuery components.
The igTree will be available , the hierarchical igGrid too.
Let me know if you have further questions.
