We have a webdatagrid.We are trying to add multiple rows to the grid on the client side by means of the client side method :
function
callCostCenterSuccess(res) {
var sArray = res.split("||")
var grid = $find('BaseCostCenterHGrid');
for (var i = 0; i < sArray.length; i++) {
var ccAttributes = sArray[i].split("~");
if (ccAttributes.length > 1) {
var newValues = new Array(ccAttributes[0], ccAttributes[1], ccAttributes[2]);
grid.get_gridView().get_rows().add(newValues);
CloseDialog(dialogCostCenter);
We are calling the client side add method in a for loop.
What we see is that the entire loop gets executed but only the last row gets added to the grid.
Is there any way we can get over this problem?
The best approach at this time is to wait for 11.2. There currently is no workaround for this issue in the WebHierarchicalDataGrid because the settings to enable this won't be available until 11.2.
As for the release of 11.2, we currently do not have a date I can provide. However, if you check the Infragistics Product Lifecycle webpage (http://ko.infragistics.com/support/product-lifecycle.aspx) you can see that historically the x.2/x.3 release for a year has come out around October. While I recommend checking for the release around that time, please note that it may be later in the year.
That is sad.
Is ther a work around for the time being to do batch updating on client for whdg?
And when is 11.2 releasing?
Hello Divya,
Batch updating in the WebHierarchicalDataGrid will be available in our 11.2 release. At this time, there is no way to implement this behavior in the WebHierarchicalDataGrid. You will be able to use this behavior once the 11.2 version is released.
Please let me know if I can be of any further assistance with this matter.
Hey please tell me how we can do the same thing for hierarchical grid?
Please provide us a way as our development hass come to a standstill because of this
