I am using VS2010, Infrag 2011 vol 1 asp.net 4
I have a webdatagrid and a data entry form with several fields on the same screen, I am loading the fields with the values from the grid when click on the grid on the RowSelectionChanged event and works but I need to press a button in order to generate the postback, is there a way that the RowSelectionChanged do the postback automatically, I don't know if I am missing something.
Thanks.
ig:Activation Enabled="true"></ig:Activation>
Hello garciama,If you have more questions about this issue do not hesitate to ask
Hi garciama,
The grid is making a postback, but whether it is ajax is determined by EnableAjax of the grid. If you have EnableAjax="true", then it is a grid postback. If you update any other controls on the form, they will not be updated. If you need to do this, turn off ajax and wrap the grid and other controls in an update panel. Now the RowSelectionChanged will trigger a full page postback.
regards,
David Young
