240
WebDialogWindow Visible/Enable
Hi Everyone,
VS2010, CLR 4.0, VB Infr 2011_1
I have a webdialogwindow wiht a WebImageviewer  in a child page that I am not able to put it visible/enable. The idea is when you click a button load the images and get the Webdialogwindow visible in modal way. If I specify the property WindowState="Normal" when the page is loaded first time works, (this is not the functionality I am looking for), the dialog has to be shown when I press the button. Once the dialog is shown, first time, because  it is modal the only action to exit is Close button in the header, after that if a press the trigger button again i don't get to have the dialog shown again.
Thanks in advance
<ig:WebDialogWindow runat="server" Width="552px" Height="430px" ID="WebDlgWind1"
InitialLocation="Centered" Moveable="False" Modal="true" WindowState "Normal">
<Header CaptionText="Image Viewer Modal" />
<ContentPane>
<Template>
<asp:UpdatePanel runat="server" ID="PanelViewer" UpdateMode="Conditional" ChildrenAsTriggers="false">
<Triggers>
<asp:AsyncPostBackTrigger ControlID="WebimagebuttonViewer" EventName="click" />
</Triggers>
<ContentTemplate>
<ig:WebImageViewer ID="WebImageViewer1" runat="server" Width="535px" Height="325px" Header-Visible="false" Footer-Visible="false" >
<ScrollAnimations>
<NextItem Alignment="Near"/>
</ScrollAnimations>
<PreviousButton Visible="True" />
<NextButton Visible="True" />
<Header Visible="false" ></Header>
</ig:WebImageViewer>
Private Sub WebimagebuttonViewer_Click(sender As Object, e As Infragistics.WebUI.WebDataInput.ButtonEventArgs) Handles
WebimagebuttonViewer.Click
Dim i As Integer  = 1
While i <= 7 Dim image As New ImageItem("/Images/IG00000/Big/" + i.ToString() + ".jpg", "", "")
Me.WebImageViewer1.Items.Add(image)
System.
Math.Max(System.Threading.Interlocked.Increment(i), i - 1)
End While
WebDlgWind1.WindowState = Infragistics.Web.UI.LayoutControls.
DialogWindowState.Normal
WebDlgWind1.Visible =
True
WebDlgWind1.Enabled =
True
End Sub
