Sorry for insert this question on this forum
I am new posting questions in the forum and using this editor . Why when I copy "line codes samples" in the editor shows so many spaces between the lines. Is there any way to format it to avoid this.
Thanks.
I haven't heard from you in a few days and just wanted to check to see if there was anything else I can do for you. If I don't hear from you in 3 days I will go ahead and close this case as inactive. Once a case is closed you will still be able to open it again within 30 days.
Please let me know if I may be of further assistance with this matter.
Sincerely,Mike P.Developer Support EngineerInfragistics, Inc.www.infragistics.com
I am following up to see if the information provided has resolved this matter.
You can insert code into a forum post by using [ code][/ code] and placing code inside of the code blocks. Note remove the spaces between the code and [ and code and / for them to operate properly.
