5368
DropDownProvider is obscured when in WebSplitter or WebTab ContentPane
Both the DatePickerProvider, and the MonthCalendarProvider intelligently display on the screen based on the location of the frame edge.  The DropDownProvider does not do this... instead, it extends below the bottom of the frame, obscuring all of the choices.
This is true whether you are editing an existing row or adding a new row.  This is particularly cumbersome when the Add New Row is at the bottom of the screen.  It means that if I want to use a DropDownProvider, I have to include a ton of whitespace below the grid for the dropdown..
Screenshot and samples:
TestPage_Parent.aspx:
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="TestPage_Parent.aspx.vb" Inherits="TestPage_Parent" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server">
    <ig:WebScriptManager ID="WebScriptManager1" runat="server">
    </ig:WebScriptManager>
    <div>
    <h6>WebDataGrid in frame of WebTab:</h6>
        <ig:WebTab ID="WebTab1" runat="server" Height="300px" Width="500px" StyleSetName="IG">
            <Tabs>
                <ig:ContentTabItem runat="server" Text="Tab 1" ScrollBars="Hidden" ContentUrl="TestPage.aspx" FrameScrolling="False">
                </ig:ContentTabItem>
                <ig:ContentTabItem runat="server" Text="Tab 2">
            </Tabs>
        </ig:WebTab>
      <h6>WebDataGrid in frame of WebSplitter:</h6>
        <ig:WebSplitter ID="WebSplitter1" runat="server" Height="300px" Width="500px" StyleSetName="IG">
            <Panes>
                <ig:SplitterPane runat="server" Collapsed="False" Size="10" BackColor="#CCFFFF">
                </ig:SplitterPane>
                <ig:SplitterPane runat="server" ScrollBars="Hidden" ContentUrl="TestPage.aspx" FrameScrolling="False">
                </ig:SplitterPane>
            </Panes>
        </ig:WebSplitter>
    </div>
    </form>
</body>
</html>
TestPage.aspx:
<%@ Page Language="VB" CodeFile="TestPage.aspx.vb" Inherits="TestPage" %>
<%@ Register Assembly="Infragistics4.Web.v11.1, Version=11.1.20111.2020, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
<head id="Head1" runat="server">
    <title></title>
    <style type="text/css">
        html, body, form
            width: 100%;
            height: 100%;
            margin: 0px;
    </style>
</head>
<body>
    <ig:WebDataGrid ID="WebDataGrid1" runat="server" StyleSetName="IG" AutoGenerateColumns="False"
        DataKeyFields="datepickerprovider" Width="100%" Height="100%">
        <Columns>
            <ig:BoundDataField DataFieldName="datepickerprovider" Key="datepickerprovider">
                <Header Text="DatePickerProvider" />
            </ig:BoundDataField>
            <ig:BoundDataField DataFieldName="dropdownprovider" Key="dropdownprovider">
                <Header Text="DropdownProvider" />
            <ig:BoundDataField DataFieldName="monthcalendarprovider" Key="monthcalendarprovider">
                <Header Text="MonthCalendarProvider" />
        </Columns>
        <EditorProviders>
            <ig:DatePickerProvider ID="WebDataGrid1_DatePickerProvider1">
                <EditorControl ID="EditorControl1" runat="server" ClientIDMode="Predictable" StyleSetName="IG">
                </EditorControl>
            </ig:DatePickerProvider>
            <ig:DropDownProvider runat="server" ID="WebDataGrid1_DropDownProvider1">
                <EditorControl ClientIDMode="Predictable" DropDownContainerMaxHeight="200px" EnableAnimations="False"
                    EnableDropDownAsChild="False" StyleSetName="IG" DropDownContainerWidth="125px">
                    <Items>
                        <ig:DropDownItem Selected="False" Text="Item 1" Value="Item 1">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 2" Value="Item 2">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 3" Value="Item 3">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 4" Value="Item 4">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 5" Value="Item 5">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 6" Value="Item 6">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 7" Value="Item 7">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 8" Value="Item 8">
                        </ig:DropDownItem>
                        <ig:DropDownItem Selected="False" Text="Item 9" Value="Item 9">
                        </ig:DropDownItem>
                    </Items>
                </EditorControl>
            </ig:DropDownProvider>
            <ig:MonthCalendarProvider ID="WebDataGrid1_MonthCalendarProvider1">
                <EditorControl ID="EditorControl2" runat="server" ClientIDMode="Predictable"  StyleSetName="IG">
                </EditorControl>
            </ig:MonthCalendarProvider>
        </EditorProviders>
        <Behaviors>
            <ig:EditingCore>
                <Behaviors>
                    <ig:CellEditing>
                        <EditModeActions MouseClick="Single" />
                        <ColumnSettings>
                            <ig:EditingColumnSetting ColumnKey="datepickerprovider" EditorID="WebDataGrid1_DatePickerProvider1" />
                            <ig:EditingColumnSetting ColumnKey="dropdownprovider" EditorID="WebDataGrid1_DropDownProvider1" />
                            <ig:EditingColumnSetting ColumnKey="monthcalendarprovider" EditorID="WebDataGrid1_MonthCalendarProvider1" />
                        </ColumnSettings>
                    </ig:CellEditing>
                    <ig:RowAdding>
                        <ColumnSettings>
                            <ig:RowAddingColumnSetting ColumnKey="datepickerprovider" EditorID="WebDataGrid1_DatePickerProvider1" />
                            <ig:RowAddingColumnSetting ColumnKey="dropdownprovider" EditorID="WebDataGrid1_DropDownProvider1" />
                            <ig:RowAddingColumnSetting ColumnKey="monthcalendarprovider" EditorID="WebDataGrid1_MonthCalendarProvider1" />
                        </ColumnSettings>
                    </ig:RowAdding>
                </Behaviors>
            </ig:EditingCore>
            <ig:RowSelectors>
            </ig:RowSelectors>
        </Behaviors>
    </ig:WebDataGrid>
    </form>
</body>
</html>
TestPage.aspx.vb:
Partial Class TestPage
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Dim tbl As New DataTable
        tbl.Columns.Add("datepickerprovider", GetType(Date))
        tbl.Columns.Add("dropdownprovider")
        tbl.Columns.Add("monthcalendarprovider", GetType(Date))
        Dim rnd As New Random()
        For i = 1 To 8
            Dim rw As DataRow = tbl.NewRow
            rw("datepickerprovider") = Today.AddDays(i)
            rw("dropdownprovider") = "Item " & rnd.Next(1, 9)
            rw("monthcalendarprovider") = Today.AddDays(i + 45)
            tbl.Rows.Add(rw)
        Next
        Me.WebDataGrid1.DataSource = tbl
    End Sub
End Class
Parents Reply Children
No Data
