hi team,
i am getting the below mentioned errors while installing the Infragistics.(NetAdvantage_Ultimate_20111)
ASP.NET: An error occurred while installing ASP.NET. The log file can be found at <a href="C:\Log Files\NetAdvantage_ASPNET_20111.msi.txt">C:\Log Files\NetAdvantage_ASPNET_20111.msi.txt</a> for further details.
ASP.NET Samples: An error occurred while installing ASP.NET Samples. The log file can be found at <a href="C:\Log Files\NetAdvantage_ASPNET_20111_Samples.msi.txt">C:\Log Files\NetAdvantage_ASPNET_20111_Samples.msi.txt</a> for further details.
jQuery: An error occurred while installing jQuery. The log file can be found at <a href="C:\Log Files\NetAdvantage_jQuery_20111.msi.txt">C:\Log Files\NetAdvantage_jQuery_20111.msi.txt</a> for further details.
jQuery Samples: An error occurred while installing jQuery Samples. The log file can be found at <a href="C:\Log Files\NetAdvantage_jQuery_20111_Samples.msi.txt">C:\Log Files\NetAdvantage_jQuery_20111_Samples.msi.txt</a> for further details.
LightSwitch: An error occurred while installing LightSwitch. The log file can be found at <a href="C:\Log Files\NetAdvantage_LightSwitch_20111.msi.txt">C:\Log Files\NetAdvantage_LightSwitch_20111.msi.txt</a> for further details.
LightSwitch Samples: An error occurred while installing LightSwitch Samples. The log file can be found at <a href="C:\Log Files\NetAdvantage_LightSwitch_20111_Samples.msi.txt">C:\Log Files\NetAdvantage_LightSwitch_20111_Samples.msi.txt</a> for further details.
Silverlight: An error occurred while installing Silverlight. The log file can be found at <a href="C:\Log Files\NetAdvantage_Silverlight_20111.msi.txt">C:\Log Files\NetAdvantage_Silverlight_20111.msi.txt</a> for further details.
Silverlight Samples: An error occurred while installing Silverlight Samples. The log file can be found at <a href="C:\Log Files\NetAdvantage_Silverlight_20111_Samples.msi.txt">C:\Log Files\NetAdvantage_Silverlight_20111_Samples.msi.txt</a> for further details.
Silverlight Data Visualization: An error occurred while installing Silverlight Data Visualization. The log file can be found at <a href="C:\Log Files\NetAdvantage_SilverlightDV_20111.msi.txt">C:\Log Files\NetAdvantage_SilverlightDV_20111.msi.txt</a> for further details.
Silverlight Data Visualization Samples: An error occurred while installing Silverlight Data Visualization Samples. The log file can be found at <a href="C:\Log Files\NetAdvantage_SilverlightDV_20111_Samples.msi.txt">C:\Log Files\NetAdvantage_SilverlightDV_20111_Samples.msi.txt</a> for further details.
Windows Forms: An error occurred while installing Windows Forms. The log file can be found at <a href="C:\Log Files\NetAdvantage_WinForms_20111.msi.txt">C:\Log Files\NetAdvantage_WinForms_20111.msi.txt</a> for further details.
------------------------------Log Details-------------------------------------
=== Verbose logging started: 07/09/2011 05:58:44 Build type: SHIP UNICODE 4.05.6001.00 Calling process: C:\NetAdvantage_Ultimate_20111.exe ===MSI (c) (30:24) [05:58:44:633]: Resetting cached policy valuesMSI (c) (30:24) [05:58:44:633]: Machine policy value 'Debug' is 0MSI (c) (30:24) [05:58:44:633]: ******* RunEngine: ******* Product: C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msi ******* Action: ******* CommandLine: **********MSI (c) (30:24) [05:58:44:633]: Client-side and UI is none or basic: Running entire install on the server.MSI (c) (30:24) [05:58:44:633]: Grabbed execution mutex.MSI (c) (30:24) [05:58:44:649]: Cloaking enabled.MSI (c) (30:24) [05:58:44:649]: Attempting to enable all disabled privileges before calling Install on ServerMSI (c) (30:24) [05:58:44:649]: Incrementing counter to disable shutdown. Counter after increment: 0MSI (s) (64:C4) [05:58:44:649]: Running installation inside multi-package transaction C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msiMSI (s) (64:C4) [05:58:44:649]: Grabbed execution mutex.MSI (s) (64:24) [05:58:44:649]: Resetting cached policy valuesMSI (s) (64:24) [05:58:44:649]: Machine policy value 'Debug' is 0MSI (s) (64:24) [05:58:44:649]: ******* RunEngine: ******* Product: C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msi ******* Action: ******* CommandLine: **********MSI (s) (64:24) [05:58:44:805]: Machine policy value 'DisableUserInstalls' is 0MSI (s) (64:24) [05:58:44:805]: Setting cached product context: User non-assigned for product: 240383F9185EDA241B7BF20F1A377C4BMSI (s) (64:24) [05:58:44:805]: Using cached product context: User non-assigned for product: 240383F9185EDA241B7BF20F1A377C4BMSI (s) (64:24) [05:58:44:805]: Setting cached product context: User non-assigned for product: 9AC087DE786021C34B9333962F4249F1MSI (s) (64:24) [05:58:44:805]: Using cached product context: User non-assigned for product: 9AC087DE786021C34B9333962F4249F1MSI (s) (64:24) [05:58:44:805]: Setting cached product context: User non-assigned for product: BCC61E9913FEA2842AF95C68387A3A85MSI (s) (64:24) [05:58:44:805]: Using cached product context: User non-assigned for product: BCC61E9913FEA2842AF95C68387A3A85MSI (s) (64:24) [05:58:44:805]: Setting cached product context: User non-assigned for product: C16872B4A65575C45B148CCE21437870MSI (s) (64:24) [05:58:44:805]: Using cached product context: User non-assigned for product: C16872B4A65575C45B148CCE21437870MSI (s) (64:24) [05:58:44:805]: Setting cached product context: User non-assigned for product: D997EE0170E22FB409D4A512E9DEA530MSI (s) (64:24) [05:58:44:805]: Using cached product context: User non-assigned for product: D997EE0170E22FB409D4A512E9DEA530MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 00002109020090400000000000F01FECMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 00002109020090400000000000F01FECMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 00002159250090400000000000F01FECMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 00002159250090400000000000F01FECMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 000021599B0090400000000000F01FECMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 000021599B0090400000000000F01FECMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 015ED8A749875BC4CBD85B41F3953A5FMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 015ED8A749875BC4CBD85B41F3953A5FMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 0357DD412DCC89733BD78393DEA644C1MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 0357DD412DCC89733BD78393DEA644C1MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 036A308183C3B2D4B9A9C03B273435C9MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 036A308183C3B2D4B9A9C03B273435C9MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 04583E7B553E3053FA7D36B5F2F2671EMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 04583E7B553E3053FA7D36B5F2F2671EMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 04925C901D4A90447ACCA1EA36C05F87MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 04925C901D4A90447ACCA1EA36C05F87MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 0A469E8E9077AEC469C93878DB30172BMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 0A469E8E9077AEC469C93878DB30172BMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 0B79C053C7D38EE4AB9A00CB3B5D2472MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 0B79C053C7D38EE4AB9A00CB3B5D2472MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 0DC1503A46F231838AD88BCDDC8E8F7CMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 0DC1503A46F231838AD88BCDDC8E8F7CMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 0EA735CBFA88DE747B26330B6DB21588MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 0EA735CBFA88DE747B26330B6DB21588MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 0F44C093DB8BF094CAB1C64A765DEF46MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 0F44C093DB8BF094CAB1C64A765DEF46MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 157EA308FB170AD429A4B1F6ECB9BA13MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 157EA308FB170AD429A4B1F6ECB9BA13MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 166F59DC4C5A5F446AAACEDD192C046BMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 166F59DC4C5A5F446AAACEDD192C046BMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 19A73DE601773813EB05BA40F36F86E9MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 19A73DE601773813EB05BA40F36F86E9MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 1FDE90624C4330B46B43553F3BCB9413MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 1FDE90624C4330B46B43553F3BCB9413MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 2235585034EBEF145B383DEAC023D685MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 2235585034EBEF145B383DEAC023D685MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 22A44CC989C32BE4EB0FA94E46877518MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 22A44CC989C32BE4EB0FA94E46877518MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 26CEA00E9203F374293161C43C0A7D01MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 26CEA00E9203F374293161C43C0A7D01MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 26DDC2EC4210AC63483DF9D4FCC5B59DMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 26DDC2EC4210AC63483DF9D4FCC5B59DMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 2B67B778F38FA5F42BD8F3936814DA6BMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 2B67B778F38FA5F42BD8F3936814DA6BMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 2E43F6A45E9061642B72A4624A886A9FMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 2E43F6A45E9061642B72A4624A886A9FMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 2F32C211630C04D4EB4DC04BB75F55C5MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 2F32C211630C04D4EB4DC04BB75F55C5MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 304DE9D5ED490AB31B6D174FDB4A216EMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 304DE9D5ED490AB31B6D174FDB4A216EMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 30A4452B0D01E5E4AB963026FF2CD081MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 30A4452B0D01E5E4AB963026FF2CD081MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 3323515BEEA94DC4D9C2F4AA8C07BD2EMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 3323515BEEA94DC4D9C2F4AA8C07BD2EMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 36282ECA4A675FB46B4FB87D91959596MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 36282ECA4A675FB46B4FB87D91959596MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 36DB5AA141662B44887A061519DE8B53MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 36DB5AA141662B44887A061519DE8B53MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 37B8EC79A5AA78941AEB05DDA1814787MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 37B8EC79A5AA78941AEB05DDA1814787MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 3CE12785E4D897B4CB1501452EDDDC01MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 3CE12785E4D897B4CB1501452EDDDC01MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 40180434BB6F9E34BA026AB85ADC90CDMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 40180434BB6F9E34BA026AB85ADC90CDMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 40DB144D845EE8F4794AB16631B5AA8AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 40DB144D845EE8F4794AB16631B5AA8AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 429D14CA86C85DB47A1AA04E71C6136AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 429D14CA86C85DB47A1AA04E71C6136AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120602FFMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120602FFMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 52DEA377735BB914E8EF8146E16397B9MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 52DEA377735BB914E8EF8146E16397B9MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 54888DB4E5A44834C90DC38ACB5CFE4AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 54888DB4E5A44834C90DC38ACB5CFE4AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 5A6FB34A0F5DAAA4FB1456990536CE44MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 5A6FB34A0F5DAAA4FB1456990536CE44MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 5C1093C35543A0E32A41B090A305076AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 5C1093C35543A0E32A41B090A305076AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 5C77E691425F05B4DBA1C212EE9E8B7FMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 5C77E691425F05B4DBA1C212EE9E8B7FMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 6030E61781384634B8F8C04C9E73B6CAMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 6030E61781384634B8F8C04C9E73B6CAMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 618B841D53763044C97D599F4240DED1MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 618B841D53763044C97D599F4240DED1MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 625B099FC7F80E641B1FC698A3B874F8MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 625B099FC7F80E641B1FC698A3B874F8MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 6372154A36D889242917359239F14AB6MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 6372154A36D889242917359239F14AB6MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 63861404CC65E0C46AFAC543ABCD4E38MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 63861404CC65E0C46AFAC543ABCD4E38MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 667FCD348386A9F4C8199DD25A68FD8AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 667FCD348386A9F4C8199DD25A68FD8AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 68AB67CA7DA746454382090000000040MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 68AB67CA7DA746454382090000000040MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 6BA4943F00966C14FA7528636228E78DMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 6BA4943F00966C14FA7528636228E78DMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 6E8A266FCD4F2A1409E1C8110F44DBCEMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 6E8A266FCD4F2A1409E1C8110F44DBCEMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 6EA51B6D250BE3636BBB4C17C4AB5690MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 6EA51B6D250BE3636BBB4C17C4AB5690MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 7B25BB75B7B63F13984FE48EEFC5FED6MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 7B25BB75B7B63F13984FE48EEFC5FED6MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 7C09972803D472632A1DF5AF9091B82BMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 7C09972803D472632A1DF5AF9091B82BMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 81CD4EC69C59ABC40816FBC36DA7402BMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 81CD4EC69C59ABC40816FBC36DA7402BMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 868D758B0B8FEE34CBB29D5EDE122F73MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 868D758B0B8FEE34CBB29D5EDE122F73MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 8A84FEFC8BFBCAE3B85AEDF4A82A76ECMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 8A84FEFC8BFBCAE3B85AEDF4A82A76ECMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 8AE822F5B9BC1A342A952D7D0EFDAA1DMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 8AE822F5B9BC1A342A952D7D0EFDAA1DMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 9040210900063D11C8EF10054038389CMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 9040210900063D11C8EF10054038389CMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 9040C10900063D11C8EF00054038389CMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 9040C10900063D11C8EF00054038389CMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 90B4E88317E3946498124FA4A392457AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 90B4E88317E3946498124FA4A392457AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 93A0A9582D6C17E4D9562DA7696E44F5MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 93A0A9582D6C17E4D9562DA7696E44F5MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 969D73F00621E9143B80FED792BAED02MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 969D73F00621E9143B80FED792BAED02MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 98E9EA339C74D0A4E9D9DB6D69A68340MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 98E9EA339C74D0A4E9D9DB6D69A68340MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 99DB51844A69EF948A58CD0FE6E9E487MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 99DB51844A69EF948A58CD0FE6E9E487MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: 9FFC1D3BAD5C095398B40428D1BD765CMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: 9FFC1D3BAD5C095398B40428D1BD765CMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: A1006E9D3CD50264FAA7086BDC8446D5MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: A1006E9D3CD50264FAA7086BDC8446D5MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: A137B8F2D2F58AE3B8523C5E4EF3B4BDMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: A137B8F2D2F58AE3B8523C5E4EF3B4BDMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: AAFDE110811D45E4F82EA4EE4A38D765MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: AAFDE110811D45E4F82EA4EE4A38D765MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: B031C88397004B640A5DCDD27D8AA9B7MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: B031C88397004B640A5DCDD27D8AA9B7MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: B3CBA12721F52334C9C01C4142FE66C6MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: B3CBA12721F52334C9C01C4142FE66C6MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: BE814C515767eb242B3B829125AD10D4MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: BE814C515767eb242B3B829125AD10D4MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: BFA6D3CD4B87F984187D036BE6C04271MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: BFA6D3CD4B87F984187D036BE6C04271MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: C10F569CAE677DB479E36432A63E217DMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: C10F569CAE677DB479E36432A63E217DMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: CBC7645893A79C3398047DD229968BF4MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: CBC7645893A79C3398047DD229968BF4MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: CEEDB4D10D030E54B8518CB0280D5A13MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: CEEDB4D10D030E54B8518CB0280D5A13MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D18D65A760467E041948A81C67C9D496MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D18D65A760467E041948A81C67C9D496MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D237ED5B83D927A4E9982A9F38D82FA6MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D237ED5B83D927A4E9982A9F38D82FA6MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D30CF9A3586C138449FCE4FD3D474979MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D30CF9A3586C138449FCE4FD3D474979MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D414BCA974396B044A35E5BFD25BD9AFMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D414BCA974396B044A35E5BFD25BD9AFMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D5001DEF8CBC5D542A88FF7CBB031412MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D5001DEF8CBC5D542A88FF7CBB031412MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: D89021029EEE9674D83D0B835080454DMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: D89021029EEE9674D83D0B835080454DMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: DA8F1F778B150944EACEFB8400370ECFMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: DA8F1F778B150944EACEFB8400370ECFMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: DC372EB09BAAB163C8239D55AE9C923EMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: DC372EB09BAAB163C8239D55AE9C923EMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: DC3BF90CC0D3D2F398A9A6D1762F70F3MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: DC3BF90CC0D3D2F398A9A6D1762F70F3MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: DDA39468D428E8B4DB27C8D5DC5CA217MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: DDA39468D428E8B4DB27C8D5DC5CA217MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: DDE7F2BCF1D91C3409CFF425AE1E271AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: DDE7F2BCF1D91C3409CFF425AE1E271AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: E754886CDF30149429B32AF7D4247ADDMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: E754886CDF30149429B32AF7D4247ADDMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: E7DAEDC68D8F7F73BAF6E12217E6033FMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: E7DAEDC68D8F7F73BAF6E12217E6033FMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: E8075689A7547D947A774BE074D2ECC4MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: E8075689A7547D947A774BE074D2ECC4MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: EA5B44F46A28A8A43A3E2ED48479823EMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: EA5B44F46A28A8A43A3E2ED48479823EMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: F526DD6C16B41654286878AC2057EC1AMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: F526DD6C16B41654286878AC2057EC1AMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: F60730A4A66673047777F5728467D401MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: F60730A4A66673047777F5728467D401MSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: FB300AA65E371194DA7B17DD6547DD4DMSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: FB300AA65E371194DA7B17DD6547DD4DMSI (s) (64:24) [05:58:44:805]: Setting cached product context: machine assigned for product: FCDAC0A0AD874C333A05DC1548B97920MSI (s) (64:24) [05:58:44:805]: Using cached product context: machine assigned for product: FCDAC0A0AD874C333A05DC1548B97920MSI (s) (64:24) [05:58:44:867]: File will have security applied from OpCode.MSI (s) (64:24) [05:58:49:352]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msi' against software restriction policyMSI (s) (64:24) [05:58:49:352]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msi has a digital signatureMSI (s) (64:24) [05:58:50:117]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msi is permitted to run at the 'unrestricted' authorization level.MSI (s) (64:24) [05:58:50:133]: End dialog not enabledMSI (s) (64:24) [05:58:50:133]: Original package ==> C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msiMSI (s) (64:24) [05:58:50:133]: Package we're running from ==> C:\WINDOWS\Installer\4de4fac.msiMSI (s) (64:24) [05:58:50:180]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C1157AB-C74D-4C08-9A1C-715AF620C83E}'.MSI (s) (64:24) [05:58:50:180]: APPCOMPAT: no matching ProductCode found in database.MSI (s) (64:24) [05:58:50:180]: MSCOREE not loaded loading copy from system32MSI (s) (64:24) [05:58:50:180]: Machine policy value 'TransformsSecure' is 0MSI (s) (64:24) [05:58:50:180]: User policy value 'TransformsAtSource' is 0MSI (s) (64:24) [05:58:50:180]: Machine policy value 'DisablePatch' is 0MSI (s) (64:24) [05:58:50:180]: Machine policy value 'AllowLockdownPatch' is 0MSI (s) (64:24) [05:58:50:180]: Machine policy value 'DisableLUAPatching' is 0MSI (s) (64:24) [05:58:50:180]: Machine policy value 'DisableFlyWeightPatching' is 0MSI (s) (64:24) [05:58:50:180]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is activeMSI (s) (64:24) [05:58:50:180]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C1157AB-C74D-4C08-9A1C-715AF620C83E}'.MSI (s) (64:24) [05:58:50:180]: APPCOMPAT: no matching ProductCode found in database.MSI (s) (64:24) [05:58:50:180]: Transforms are not secure.MSI (s) (64:24) [05:58:50:180]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Log Files\NetAdvantage_ASPNET_20111.msi.txt'.MSI (s) (64:24) [05:58:50:180]: Command Line: INSTALL_SERIALNUM=921453008325955889 FEEDBACK=1 INSTALLDIR=C:\Program Files\Infragistics COMPANYNAME=Schroders USERNAME=Schroders AGREE_AND_INSTALL_OFFICE_2007_UI=No INSTALLLEVEL=1000 ADDLOCAL=ASPNET,AppStylistForASPNET,ASPNETIIS,NETToolboxUtility CURRENTDIRECTORY=C:\ CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=4912 MSI (s) (64:24) [05:58:50:180]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{1DF2CD78-9420-4805-9C31-27296071B34A}'.MSI (s) (64:24) [05:58:50:180]: Product Code passed to Engine.Initialize: ''MSI (s) (64:24) [05:58:50:180]: Product Code from property table before transforms: '{5C1157AB-C74D-4C08-9A1C-715AF620C83E}'MSI (s) (64:24) [05:58:50:180]: Product Code from property table after transforms: '{5C1157AB-C74D-4C08-9A1C-715AF620C83E}'MSI (s) (64:24) [05:58:50:180]: Product not registered: beginning first-time installMSI (s) (64:24) [05:58:50:195]: Product {5C1157AB-C74D-4C08-9A1C-715AF620C83E} is not managed.MSI (s) (64:24) [05:58:50:195]: MSI_LUA: Credential prompt functionality not available on this operating systemMSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.MSI (s) (64:24) [05:58:50:195]: Entering CMsiConfigurationManager::SetLastUsedSource.MSI (s) (64:24) [05:58:50:195]: Policy value 'SearchOrder' is 'n'MSI (s) (64:24) [05:58:50:195]: Adding new sources is allowed.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.MSI (s) (64:24) [05:58:50:195]: Package name extracted from package path: 'NetAdvantage_ASPNET_20111.msi'MSI (s) (64:24) [05:58:50:195]: Package to be registered: 'NetAdvantage_ASPNET_20111.msi'MSI (s) (64:24) [05:58:50:195]: Note: 1: 2262 2: AdminProperties 3: -2147287038 MSI (s) (64:24) [05:58:50:195]: Machine policy value 'DisableMsi' is 0MSI (s) (64:24) [05:58:50:195]: Machine policy value 'AlwaysInstallElevated' is 1MSI (s) (64:24) [05:58:50:195]: User policy value 'AlwaysInstallElevated' is 1MSI (s) (64:24) [05:58:50:195]: Running product '{5C1157AB-C74D-4C08-9A1C-715AF620C83E}' with elevated privileges: All apps run elevated.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding INSTALL_SERIALNUM property. Its value is '921453008325955889'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding FEEDBACK property. Its value is '1'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files\Infragistics'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Schroders'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Schroders'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Modifying AGREE_AND_INSTALL_OFFICE_2007_UI property. Its current value is 'Unread'. Its new value: 'No'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1000'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'ASPNET,AppStylistForASPNET,ASPNETIIS,NETToolboxUtility'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding MSICLIENTUSESEXTERNALUI property. Its value is '1'.MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4912'.MSI (s) (64:24) [05:58:50:195]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0MSI (s) (64:24) [05:58:50:195]: DisableAutomaticApplicationShutdown system policy is ignored on this version of Windows.MSI (s) (64:24) [05:58:50:195]: TRANSFORMS property is now: MSI (s) (64:24) [05:58:50:195]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '301'.MSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\Application DataMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: L:\My Documents\FavoritesMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\NetHoodMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: L:\My DocumentsMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\PrintHoodMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\RecentMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\SendToMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\TemplatesMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application DataMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\Local Settings\Application DataMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\My Documents\My PicturesMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\Start Menu\Programs\Administrative ToolsMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\Start Menu\Programs\StartupMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\Start Menu\ProgramsMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\Start MenuMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\balagob\DesktopMSI (s) (64:24) [05:58:50:195]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative ToolsMSI (s) (64:24) [05:58:50:211]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\StartupMSI (s) (64:24) [05:58:50:211]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\ProgramsMSI (s) (64:24) [05:58:50:211]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start MenuMSI (s) (64:24) [05:58:50:211]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\DesktopMSI (s) (64:24) [05:58:50:211]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\FontsMSI (s) (64:24) [05:58:50:211]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16 MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\Installer\4de4fac.msi'.MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Documents and Settings\All Users\Application Data\Infragistics\NetAdvantage_ASPNET_20111.msi'.MSI (s) (64:24) [05:58:50:211]: Machine policy value 'MsiDisableEmbeddedUI' is 0MSI (s) (64:24) [05:58:50:211]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UIMSI (s) (64:24) [05:58:50:211]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic installMSI (s) (64:24) [05:58:50:211]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (64:24) [05:58:50:211]: Machine policy value 'DisableRollback' is 0MSI (s) (64:24) [05:58:50:211]: User policy value 'DisableRollback' is 0MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.=== Logging started: 07/09/2011 05:58:50 ===MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.MSI (s) (64:24) [05:58:50:211]: Doing action: INSTALLAction start 05:58:50: INSTALL.MSI (s) (64:24) [05:58:50:211]: Running ExecuteSequenceMSI (s) (64:24) [05:58:50:211]: Doing action: ProgramMenuFolder.9EB7DA74_FB02_45E2_8694_A7E59466AC5CMSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding ProgramMenuFolder.9EB7DA74_FB02_45E2_8694_A7E59466AC5C property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.9EB7DA74_FB02_45E2_8694_A7E59466AC5C.MSI (s) (64:24) [05:58:50:211]: Doing action: ProgramMenuFolder.6042B615_72D9_44C7_8A02_F8CABD695AB0Action ended 05:58:50: ProgramMenuFolder.9EB7DA74_FB02_45E2_8694_A7E59466AC5C. Return value 1.MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding ProgramMenuFolder.6042B615_72D9_44C7_8A02_F8CABD695AB0 property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.6042B615_72D9_44C7_8A02_F8CABD695AB0.MSI (s) (64:24) [05:58:50:211]: Doing action: ProgramMenuFolder.CD1CB064_6B7A_4C32_B200_4EBD8ED935F4Action ended 05:58:50: ProgramMenuFolder.6042B615_72D9_44C7_8A02_F8CABD695AB0. Return value 1.MSI (s) (64:24) [05:58:50:211]: PROPERTY CHANGE: Adding ProgramMenuFolder.CD1CB064_6B7A_4C32_B200_4EBD8ED935F4 property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.CD1CB064_6B7A_4C32_B200_4EBD8ED935F4.MSI (s) (64:24) [05:58:50:211]: Doing action: ProgramMenuFolder.2BE83A8B_EF64_411D_A431_01D9986204CDAction ended 05:58:50: ProgramMenuFolder.CD1CB064_6B7A_4C32_B200_4EBD8ED935F4. Return value 1.MSI (s) (64:24) [05:58:50:227]: PROPERTY CHANGE: Adding ProgramMenuFolder.2BE83A8B_EF64_411D_A431_01D9986204CD property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.2BE83A8B_EF64_411D_A431_01D9986204CD.MSI (s) (64:24) [05:58:50:227]: Doing action: ProgramMenuFolder.B88DD044_1905_4378_A323_79107F21009FAction ended 05:58:50: ProgramMenuFolder.2BE83A8B_EF64_411D_A431_01D9986204CD. Return value 1.MSI (s) (64:24) [05:58:50:227]: PROPERTY CHANGE: Adding ProgramMenuFolder.B88DD044_1905_4378_A323_79107F21009F property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.B88DD044_1905_4378_A323_79107F21009F.MSI (s) (64:24) [05:58:50:227]: Doing action: ProgramMenuFolder.9C5424A6_AA6A_430A_86BA_D83F4908FD1AAction ended 05:58:50: ProgramMenuFolder.B88DD044_1905_4378_A323_79107F21009F. Return value 1.MSI (s) (64:24) [05:58:50:227]: PROPERTY CHANGE: Adding ProgramMenuFolder.9C5424A6_AA6A_430A_86BA_D83F4908FD1A property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.9C5424A6_AA6A_430A_86BA_D83F4908FD1A.MSI (s) (64:24) [05:58:50:227]: Doing action: ProgramMenuFolder.D6CB2ED3_ED4C_4B16_BB96_9EAD117015C8Action ended 05:58:50: ProgramMenuFolder.9C5424A6_AA6A_430A_86BA_D83F4908FD1A. Return value 1.MSI (s) (64:24) [05:58:50:227]: PROPERTY CHANGE: Adding ProgramMenuFolder.D6CB2ED3_ED4C_4B16_BB96_9EAD117015C8 property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\'.Action start 05:58:50: ProgramMenuFolder.D6CB2ED3_ED4C_4B16_BB96_9EAD117015C8.MSI (s) (64:24) [05:58:50:227]: Doing action: GetDotNetVersionAction ended 05:58:50: ProgramMenuFolder.D6CB2ED3_ED4C_4B16_BB96_9EAD117015C8. Return value 1.MSI (s) (64:24) [05:58:50:227]: Creating MSIHANDLE (470) of type 790542 for thread 4132MSI (s) (64:38) [05:58:50:227]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI156.tmp, Entrypoint: GetDotNetVersionMSI (s) (64:58) [05:58:50:227]: Generating random cookie.MSI (s) (64:58) [05:58:50:227]: Created Custom Action Server with PID 5472 (0x1560).MSI (s) (64:FC) [05:58:50:258]: Running as a service.MSI (s) (64:FC) [05:58:50:258]: Hello, I'm your 32bit Impersonated custom action server.MSI (s) (64!AC) [05:58:50:289]: Creating MSIHANDLE (471) of type 790531 for thread 4268Action start 05:58:50: GetDotNetVersion.MSI (s) (64!AC) [05:58:50:289]: Closing MSIHANDLE (471) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:305]: Creating MSIHANDLE (472) of type 790531 for thread 4268SFXCA: Extracting custom action to temporary directory: C:\WINDOWS\Installer\MSI156.tmp-\MSI (s) (64!AC) [05:58:50:305]: Closing MSIHANDLE (472) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:414]: Creating MSIHANDLE (473) of type 790531 for thread 4268SFXCA: Binding to CLR version v2.0.50727MSI (s) (64!AC) [05:58:50:430]: Closing MSIHANDLE (473) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (474) of type 790531 for thread 4268Calling custom action IGCustomActions!IGCustomActions.CustomActions.GetDotNetVersionMSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (474) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (475) of type 790531 for thread 4268Starting GetDotNetVersion action.MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (475) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETCDF property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (476) of type 790531 for thread 4268Finding installed .NET Framework versions.MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (476) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETV1.1.4322 property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (477) of type 790531 for thread 4268Setting DOTNETCDF to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (477) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETV2.0.50727 property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (478) of type 790531 for thread 4268Setting DOTNETV1.1.4322 to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (478) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETV3.0 property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (479) of type 790531 for thread 4268Setting DOTNETV2.0.50727 to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (479) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETV3.5 property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (480) of type 790531 for thread 4268Setting DOTNETV3.0 to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (480) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETV4 property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (481) of type 790531 for thread 4268Setting DOTNETV3.5 to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (481) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: PROPERTY CHANGE: Adding DOTNETV4.0 property. Its value is '1'.MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (482) of type 790531 for thread 4268Setting DOTNETV4 to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (482) of type 790531 for thread 4268MSI (s) (64!AC) [05:58:50:461]: Creating MSIHANDLE (483) of type 790531 for thread 4268Setting DOTNETV4.0 to 1MSI (s) (64!AC) [05:58:50:461]: Closing MSIHANDLE (483) of type 790531 for thread 4268MSI (s) (64:38) [05:58:50:461]: Closing MSIHANDLE (470) of type 790542 for thread 4132Finished GetDotNetVersion action successfully.MSI (s) (64:24) [05:58:50:461]: Skipping action: StorePassedInSerialNumber (condition is false)MSI (s) (64:24) [05:58:50:461]: Doing action: AppSearchAction ended 05:58:50: GetDotNetVersion. Return value 1.Action start 05:58:50: AppSearch.MSI (s) (64:24) [05:58:50:461]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:461]: PROPERTY CHANGE: Adding COMMON_DOCUMENTS_LOC property. Its value is 'C:\Documents and Settings\All Users\Documents'.MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: PROPERTY CHANGE: Modifying VS2010_INSTALLED property. Its current value is '0'. Its new value: 'C:\Program Files\Microsoft Visual Studio 10.0\Common7\IDE\'.MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full\CLR2x\Version11.1\HelpInstallDir 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full\CLR2x\Version11.1\InstallDir 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full\CLR2x\Version11.1\SDKInstallDir 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: PROPERTY CHANGE: Adding FRAMEWORK_INSTALL_ROOT property. Its value is 'C:\WINDOWS\Microsoft.NET\Framework\'.MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\InetStp 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Self\ASP.NET\CLR2x\Version11.1\ProductID 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\CLR2x\Version11.1\ProductID 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full\CLR2x\Version11.1\ProductID 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\CLR2x\Version11.1\ProductID 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full\ASP.NET\CLR2x\Version11.1\ProductID 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Classes\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (64:24) [05:58:50:477]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Infragistics\Installer\{5C1157AB-C74D-4C08-9A1C-715AF620C83E} 3: 2 MSI (s) (64:24) [05:58:50:477]: Skipping action: SetIgShortcutDirLocAllUsers (condition is false)MSI (s) (64:24) [05:58:50:477]: Skipping action: SetIgShortcutDirLocPerUser (condition is false)MSI (s) (64:24) [05:58:50:477]: Doing action: SearchProductCodeRegistryKeysAction ended 05:58:50: AppSearch. Return value 1.MSI (s) (64:24) [05:58:50:477]: Creating MSIHANDLE (484) of type 790542 for thread 4132MSI (s) (64:C8) [05:58:50:477]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI157.tmp, Entrypoint: SearchProductCodeRegistryKeysMSI (s) (64!F4) [05:58:50:523]: Creating MSIHANDLE (485) of type 790531 for thread 5364Action start 05:58:50: SearchProductCodeRegistryKeys.MSI (s) (64!F4) [05:58:50:523]: Closing MSIHANDLE (485) of type 790531 for thread 5364MSI (s) (64!F4) [05:58:50:523]: Creating MSIHANDLE (486) of type 790531 for thread 5364SFXCA: Extracting custom action to temporary directory: C:\WINDOWS\Installer\MSI157.tmp-\MSI (s) (64!F4) [05:58:50:523]: Closing MSIHANDLE (486) of type 790531 for thread 5364MSI (s) (64!F4) [05:58:50:648]: Creating MSIHANDLE (487) of type 790531 for thread 5364SFXCA: Binding to CLR version v2.0.50727MSI (s) (64!F4) [05:58:50:648]: Closing MSIHANDLE (487) of type 790531 for thread 5364MSI (s) (64!F4) [05:58:50:695]: PROPERTY CHANGE: Adding _WPFDVPRODUCTGUID property. Its value is '{E49C7FAA-2B67-B587-1084-375596DD3CF6}'.MSI (s) (64:C8) [05:58:50:695]: Closing MSIHANDLE (484) of type 790542 for thread 4132Calling custom action IGCustomActions!IGCustomActions.CustomActions.SearchProductCodeRegistryKeysMSI (s) (64:24) [05:58:50:695]: Skipping action: SetSerialNumberToStoredValue (condition is false)MSI (s) (64:24) [05:58:50:695]: Doing action: LaunchConditionsAction ended 05:58:50: SearchProductCodeRegistryKeys. Return value 1.Action start 05:58:50: LaunchConditions.MSI (s) (64:24) [05:58:50:695]: Skipping action: SetReinstallProperty (condition is false)MSI (s) (64:24) [05:58:50:695]: Skipping action: SetReinstallmode (condition is false)MSI (s) (64:24) [05:58:50:695]: Doing action: ValidateKeyAction ended 05:58:50: LaunchConditions. Return value 1.MSI (s) (64:24) [05:58:50:711]: Creating MSIHANDLE (488) of type 790542 for thread 4132MSI (s) (64:4C) [05:58:50:711]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI158.tmp, Entrypoint: ValidateKeyMSI (s) (64!18) [05:58:50:742]: Creating MSIHANDLE (489) of type 790531 for thread 3096Action start 05:58:50: ValidateKey.MSI (s) (64!18) [05:58:50:742]: Closing MSIHANDLE (489) of type 790531 for thread 3096MSI (s) (64!18) [05:58:50:758]: Creating MSIHANDLE (490) of type 790531 for thread 3096SFXCA: Extracting custom action to temporary directory: C:\WINDOWS\Installer\MSI158.tmp-0\MSI (s) (64!18) [05:58:50:758]: Closing MSIHANDLE (490) of type 790531 for thread 3096MSI (s) (64!18) [05:58:50:898]: Creating MSIHANDLE (491) of type 790531 for thread 3096SFXCA: Binding to CLR version v2.0.50727MSI (s) (64!18) [05:58:50:898]: Closing MSIHANDLE (491) of type 790531 for thread 3096MSI (s) (64!18) [05:58:50:961]: Creating MSIHANDLE (492) of type 790531 for thread 3096Calling custom action IGCustomActions!IGCustomActions.CustomActions.ValidateKeyMSI (s) (64!18) [05:58:50:961]: Closing MSIHANDLE (492) of type 790531 for thread 3096MSI (s) (64!18) [05:58:51:117]: PROPERTY CHANGE: Adding _INSTALL_PROD_CODE property. Its value is '92'.MSI (s) (64!18) [05:58:51:117]: PROPERTY CHANGE: Adding ValidKey property. Its value is '1'.MSI (s) (64:4C) [05:58:51:117]: Closing MSIHANDLE (488) of type 790542 for thread 4132Acceptable prefix found. Will validate the keyMSI (s) (64:24) [05:58:51:133]: Doing action: ValidateProductIDAction ended 05:58:51: ValidateKey. Return value 1.Action start 05:58:51: ValidateProductID.MSI (s) (64:24) [05:58:51:133]: Skipping action: SetProductString.C61AB576_AC37_4EE8_8278_836F6068A4A8 (condition is false)MSI (s) (64:24) [05:58:51:133]: Skipping action: SetProductString.787C574D_C74C_49A8_A371_B7DEF648C471 (condition is false)MSI (s) (64:24) [05:58:51:133]: Skipping action: SetProductString.C5AE2903_EFAC_415F_9898_FB52635E9097 (condition is false)MSI (s) (64:24) [05:58:51:133]: Doing action: SetProductString.4FD94E14_A5A6_4E87_9BC2_A74B2D56AF30Action ended 05:58:51: ValidateProductID. Return value 1.MSI (s) (64:24) [05:58:51:133]: PROPERTY CHANGE: Modifying PRODUCT_STRING property. Its current value is '0'. Its new value: 'Infragistics\NetAdvantage\Net\CLR2x;Version11.1;{FCF31B8B-A325-4C88-9D25-889697B7902C};S'.Action start 05:58:51: SetProductString.4FD94E14_A5A6_4E87_9BC2_A74B2D56AF30.MSI (s) (64:24) [05:58:51:133]: Skipping action: SetProductString.93638937_BAB6_4EE6_83A5_45F6C4759F3D (condition is false)MSI (s) (64:24) [05:58:51:133]: Doing action: CostInitializeAction ended 05:58:51: SetProductString.4FD94E14_A5A6_4E87_9BC2_A74B2D56AF30. Return value 1.MSI (s) (64:24) [05:58:51:133]: Machine policy value 'MaxPatchCacheSize' is 10MSI (s) (64:24) [05:58:51:133]: Baseline: Sorting baselines for {5C1157AB-C74D-4C08-9A1C-715AF620C83E}.MSI (s) (64:24) [05:58:51:133]: Baseline: New baseline 11.1.0 from transaction.MSI (s) (64:24) [05:58:51:133]: Baseline: Sorted order Native: Order 0.MSI (s) (64:24) [05:58:51:133]: Baseline Data Table:MSI (s) (64:24) [05:58:51:133]: ProductCode: {5C1157AB-C74D-4C08-9A1C-715AF620C83E} Version: 11.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0MSI (s) (64:24) [05:58:51:133]: Baseline File Table:Action start 05:58:51: CostInitialize.MSI (s) (64:24) [05:58:51:133]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.MSI (s) (64:24) [05:58:51:148]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.MSI (s) (64:24) [05:58:51:148]: Note: 1: 2205 2: 3: Patch MSI (s) (64:24) [05:58:51:148]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (64:24) [05:58:51:148]: Note: 1: 2205 2: 3: MsiPatchHeaders MSI (s) (64:24) [05:58:51:148]: Note: 1: 2205 2: 3: __MsiPatchFileList MSI (s) (64:24) [05:58:51:148]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (64:24) [05:58:51:148]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId` MSI (s) (64:24) [05:58:51:148]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'MSI (s) (64:24) [05:58:51:148]: Note: 1: 2205 2: 3: Patch MSI (s) (64:24) [05:58:51:148]: Doing action: FileCostAction ended 05:58:51: CostInitialize. Return value 1.MSI (s) (64:24) [05:58:51:164]: Note: 1: 2205 2: 3: Class MSI (s) (64:24) [05:58:51:164]: Note: 1: 2205 2: 3: Extension MSI (s) (64:24) [05:58:51:164]: Note: 1: 2205 2: 3: TypeLib Action start 05:58:51: FileCost.MSI (s) (64:24) [05:58:51:164]: Doing action: SetDefaultIgShortcutDirAction ended 05:58:51: FileCost. Return value 1.MSI (s) (64:24) [05:58:51:164]: PROPERTY CHANGE: Adding IGSHORTCUTDIR property. Its value is 'C:\Documents and Settings\balagob\Start Menu\Programs\Infragistics'.Action start 05:58:51: SetDefaultIgShortcutDir.MSI (s) (64:24) [05:58:51:164]: Skipping action: SetCustomIgShortcutDir (condition is false)MSI (s) (64:24) [05:58:51:164]: Doing action: CostFinalizeAction ended 05:58:51: SetDefaultIgShortcutDir. Return value 1.MSI (s) (64:24) [05:58:51:164]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.MSI (s) (64:24) [05:58:51:164]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.MSI (s) (64:24) [05:58:51:164]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.MSI (s) (64:24) [05:58:51:164]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.MSI (s) (64:24) [05:58:51:164]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.MSI (s) (64:24) [05:58:51:164]: Note: 1: 2205 2: 3: Patch MSI (s) (64:24) [05:58:51:195]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.MSI (s) (64:24) [05:58:51:195]: PROPERTY CHANGE: Adding INSTALLDIR.C61AB576_AC37_4EE8_8278_836F6068A4A8 property. Its value is 'C:\WINDOWS\system32\UltimateKeys\'.MSI (s) (64:24) [05:58:51:195]: PROPERTY CHANGE: Adding INSTALLDIR.787C574D_C74C_49A8_A371_B7DEF648C471 property. Its value is 'C:\WINDOWS\system32\UltimateKeys\'.MSI (s) (64:24) [05:58:51:211]: PROPERTY CHANGE: Adding INSTALLDIR.C5AE2903_EFAC_415F_9898_FB52635E9097 property. Its value is 'C:\WINDOWS\system32\UltimateKeys\'.MSI (s) (64:24) [05:58:51:211]: PROPERTY CHANGE: Adding INSTALLDIR.4FD94E14_A5A6_4E87_9BC2_A74B2D56AF30 property. Its value is 'C:\WINDOWS\system32\UltimateKeys\'.MSI (s) (64:24) [05:58:51:211]: PROPERTY CHANGE: Adding INSTALLDIR.93638937_BAB6_4EE6_83A5_45F6C4759F3D property. Its value is 'C:\WINDOWS\system32\UltimateKeys\'.MSI (s) (64:24) [05:58:51:211]: PROPERTY CHANGE: Adding INSTALLDIR.B2768727_084D_4283_A045_7A86BAF639DC property. Its value is 'C:\WINDOWS\system32\GAC\'.MSI (s) (64:24) [05:58:51:211]: Note: 1: 1327 2: L:\ Action start 05:58:51: CostFinalize.MSI (s) (64:24) [05:58:51:211]: Product: Infragistics NetAdvantage ASP.NET 2011.1 -- Error 1327. Invalid Drive: L:\
Error 1327. Invalid Drive: L:\Action ended 05:58:51: CostFinalize. Return value 3.Action ended 05:58:51: INSTALL. Return value 3.MSI (s) (64:24) [05:58:51:211]: Windows Installer installed the product. Product Name: Infragistics NetAdvantage ASP.NET 2011.1. Product Version: 11.1.0. Product Language: 1033. Installation success or error status: 1603.
MSI (s) (64:24) [05:58:51:227]: Cleaning up uninstalled install packages, if any existMSI (s) (64:24) [05:58:51:227]: MainEngineThread is returning 1603MSI (s) (64:C4) [05:58:51:336]: No System Restore sequence number for this installation.=== Logging stopped: 07/09/2011 05:58:51 ===MSI (s) (64:C4) [05:58:51:336]: User policy value 'DisableRollback' is 0MSI (s) (64:C4) [05:58:51:336]: Machine policy value 'DisableRollback' is 0MSI (s) (64:C4) [05:58:51:336]: Incrementing counter to disable shutdown. Counter after increment: 0MSI (s) (64:C4) [05:58:51:336]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (64:C4) [05:58:51:336]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (64:C4) [05:58:51:336]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2 MSI (s) (64:C4) [05:58:51:336]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2 MSI (s) (64:C4) [05:58:51:336]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1MSI (s) (64:C4) [05:58:51:336]: Restoring environment variablesMSI (s) (64:C4) [05:58:51:336]: Destroying RemoteAPI object.MSI (s) (64:58) [05:58:51:336]: Custom Action Manager thread ending.MSI (c) (30:24) [05:58:51:336]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1MSI (c) (30:24) [05:58:51:336]: MainEngineThread is returning 1603=== Verbose logging stopped: 07/09/2011 05:58:51 ===
thanks
Hi bilsa,
It has been some time since your post, however in case you still need assistance I would be glad to help.
Please refer to the following thread for more information on installing .NetAdvantage 11.1:
http://blogs.infragistics.com/forums/p/56644/290398.aspx
