I have webforms that serve multiple functions. I have a WebSplitter splitting the screen vertically, with criteria selection on the left, and the report or content on the right.
Sometimes, the criteria is provided by a querystring. In these instances, I want to completely hide the criteria pane, and I don't want the splitter bar to be visible. I just want the content to be visible.
Is there an easy way to do this?
Thank you very much!
Hello Rob,
Thank you for reporting this.
We will pay attention and will get back to you.
Also, since the WebSplitter and WebTab both use a ContentPane template, I wouldn't be surprised if the same issues are present in controls hosted in a WebTab.
I just haven't run across any or had time to build a test.
Sure, I have made two forum posts, and have submitted a support ticket for each.
Between these two issues, the WebDataTree issue is the most important. But because both are related to the WebSplitter, I wouldn't be surprised if the same fix corrects both issues.
Hi Rob,
Can you please share the issues that you experience in the new build ( I guess you mean 2064 of v11.1) ?
Hope hearing from you.
