5368
WebDataMenu Itemclick event not firing
I have just upgraded to the new SR.  I don't know if that has anything to do with this issue.
I have an AutoPostBack flag set for ItemClick, and I have code-behind on the ItemClick event.
<AutoPostBackFlags ItemClick="On" />
It is a full page postback, and I can see the postback take place.  However, none of the code in the ItemClick codebehind is executing.
I have not had time to fully document....  has anyone else encountered this?
The only thing the least bit tricky is that I have also bound ItemClick on the client side, so that I can cancel the postback on some of the higher level menu items.  Nothing too fancy... I just do eventArgs.set_cancel(true); only for those top-level nodes.  They behave as expected and do not trigger a postback.
  • 5368
    This is a bug... and it is related to the WebDataMenu being inside a WebSplitter pane.
    The following page contains two identical WebDataMenus.  One is inside a splitter pane, and the other is outside.
    Both menus are configured to only allow ItemClick to proceed if a child is clicked.  Both trigger the postback if a child is clicked.  However, the ItemClick codebehind only executes for the WebDataMenu outside the WebSplitter pane.
    TestPage.aspx
    <%@ Page Language="VB" AutoEventWireup="false" CodeFile="TestPage.aspx.vb" Inherits="TestPage" %>
    <%@ Register Assembly="Infragistics4.Web.v11.1, Version=11.1.20111.2064, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
        Namespace="Infragistics.Web.UI.NavigationControls" TagPrefix="ig" %>
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head runat="server">
        <title></title>
        <script type="text/javascript" id="igClientScript">
            function WebDataMenu1_ItemClick(sender, eventArgs) {
                ///<summary>
                ///</summary>
                ///<param name="sender" type="Infragistics.Web.UI.WebDataMenu"></param>
                ///<param name="eventArgs" type="Infragistics.Web.UI.DataMenuItemCancelEventArgs"></param>
                if (eventArgs.getItem().get_key() == "nopostback") {
            function WebDataMenu2_ItemClick(sender, eventArgs) {
                ///<summary>
                ///</summary>
        </script>
    </head>
    <body>
        <form id="form1" runat="server">
        <ig:WebScriptManager ID="WebScriptManager1" runat="server">
        </ig:WebScriptManager>
        <div style="position: absolute; left: 0px; right: 0px; top: 0px; bottom: 0px; overflow: hidden;">
            <ig:WebSplitter ID="WebSplitter1" ClientIDMode="Static" runat="server" StyleSetName="Caribbean"
                Height="50%" Width="99.9%">
                <Panes>
                    <ig:SplitterPane runat="server" Size="185px" CollapsedDirection="PreviousPane" BackColor="OldLace"
                        FrameScrolling="False" ScrollBars="Hidden">
                        <Template>
                            Inside a splitter pane
                            <ig:WebDataMenu ID="WebDataMenu1" runat="server" EnableExpandOnClick="True">
                                <ClientEvents ItemClick="WebDataMenu1_ItemClick" />
                            </ig:WebDataMenu>
                            <asp:Label ID="Label1" runat="server" Text="Label"></asp:Label>
                        </Template>
                    </ig:SplitterPane>
                </Panes>
            </ig:WebSplitter>
            Outside a splitter pane
            <ig:WebDataMenu ID="WebDataMenu2" runat="server" EnableExpandOnClick="True">
            </ig:WebDataMenu>
            <asp:Label ID="Label2" runat="server" Text="Label"></asp:Label>
        </div>
        </form>
    </body>
    </html>
    TestPage.aspx.vb
    Imports Infragistics.Web.UI.NavigationControls
    Partial Class TestPage
        Inherits System.Web.UI.Page
        Protected Sub Page_Load(sender As Object, e As System.EventArgs) Handles Me.Load
            Response.Cache.SetCacheability(HttpCacheability.NoCache)
            If Not IsPostBack Then
                BindMenu(WebDataMenu1)
                BindMenu(WebDataMenu2)
            End If
        End Sub
        Private Sub BindMenu(menu As WebDataMenu)
            Dim itmParent As DataMenuItem
            itmParent = New DataMenuItem("Parent Item 1 (no postback)")
            itmParent.Key = "nopostback"
            menu.Items.Add(itmParent)
            itmParent.Items.Add("Child Item 1 (postback)")
            itmParent.Items.Add("Child Item 2 (postback)")
            itmParent.Items.Add("Child Item 3 (postback)")
            itmParent = New DataMenuItem("Parent Item 2 (no postback)")
        End Sub
        Protected Sub WebDataMenu1_ItemClick(sender As Object, e As Infragistics.Web.UI.NavigationControls.DataMenuItemEventArgs) Handles WebDataMenu1.ItemClick
            Me.Label1.Text = "Item Clicked: " & Now.ToShortTimeString
        End Sub
        Protected Sub WebDataMenu2_ItemClick(sender As Object, e As Infragistics.Web.UI.NavigationControls.DataMenuItemEventArgs) Handles WebDataMenu2.ItemClick
            Me.Label2.Text = "Item Clicked: " & Now.ToShortTimeString
        End Sub
    End Class
