140
Excel Export IndexOutOfRangeException
In order to combat the various speed issues when exporting large amounts of data to excel I implemented a routine that converts a dataset to an excel spreadsheet.  It worked correctly in version 11.1.20111.1006 of infragistics but since I upgraded to 11.1.20111.2036 I have had one particular dataset that causes the conversion routine to fail randomly with an IndexOutOfRangeException.  Using the debugger I can check the value of the excel cell and it correctly returns "Nothing".  I can check the datatable row and column that are being read and correctly retrive the string value of "198004"  If I trap for that cell and ignore it, then the procedure continues to run and crashes later on with the same error on several other cells.  The data table being used has 9259 rows and 23 columns so I should not be exceeding any type of excel limit.  Did something change between the two versions?
The line of code the program crashes on is:
sheetToAddTo.Rows(iRow + 1).Cells(iCol).Value = dataTable.Rows(iRow)(iCol).ToString
Here is the function including the loops
Private
Shared Sub AddData(ByVal dataTable As System.Data.DataTable, ByRef sheetToAddTo As Infragistics.Documents.Excel.Worksheet)
Dim i As Integer = 0
'add the column names from the datatable
For i = 0 To dataTable.Columns.Count - 1
sheetToAddTo.Rows(0).Cells(i).Value = dataTable.Columns(i).ColumnName
Next
'insert the data into the object[,]
Dim iRow As Integer = 0
Dim iCol As Integer = 0
For iRow = 0 To dataTable.Rows.Count - 1
For iCol = 0 To dataTable.Columns.Count - 1
Try
Catch ex As ArgumentException
If ex.Message = "String values assigned to a cell cannot have a length greater than 32767."
Then
'trapping for exceptionally long strings (> 32767) this is an excel limit
'customer has requested that we get the last 32767 characters
Dim TrappedLongString As String = dataTable.Rows(iRow)(iCol).ToString
'change vbcrlf to chr(13), that saves us one character per crlf so we can actually hit the 32767 mark.
TrappedLongString = TrappedLongString.Replace(vbCrLf, Chr(13))
sheetToAddTo.Rows(iRow + 1).Cells(iCol).Value = Mid(TrappedLongString, TrappedLongString.Length - 32766, 32767)
End If
End Try
Next
Next
End Sub
