Hi, i can't set the EditorControl-TextMode="MultiLine" attribute of the TextBoxProvider, just one row is displayed inside the control "txtDescrizione":
<EditorProviders><ig:TextBoxProvider ID="txtDescrizione" EditorControl-TextMode="MultiLine"><EditorControl TextMode="MultiLine"></EditorControl></ig:TextBoxProvider><ig:TextBoxProvider ID="txtCommento"><EditorControl ID="_txtCommento" TextMode="MultiLine"></EditorControl></ig:TextBoxProvider></EditorProviders>
Thanks a lot.
Roxanne
I am following up to see if the information provided has resolved this matter.
Please let me know if I may be of further assistance with this matter.
Sincerely,Mike P.Developer Support EngineerInfragistics, Inc.www.infragistics.com
Thank you for the update. I have created and attached a sample to demonstrate multiline TextBoxProvider. If you click to edit the Description column you will notice the longer ones display on multiple lines.
Please let me know if you have any other questions concerning this matter.
Hi Mike, i try to follow the steps suggested in your link, but it doesn't work.
Do you have some examples about it?
Thank you a lot.
Roxane
I haven't heard from you in a few days and just wanted to check to see if there was anything else I can do for you. If I don't hear from you in 3 days I will go ahead and close this case as inactive. Once a case is closed you will still be able to open it again within 30 days.
Please let me know if I may be if further assistance with this matter.
I am following up to see if the information provided has resolved this issue.
