95
WebDataMenu | WebExplorerBar | WebDataTree Not Rendering
On Sept 14 I applied the latest service pack for NetAdvantage 2011.1. Afterward the WebDataMenu, WebExplorerBar and WebDataTree controls will not render.
All the other controls appear to work.
I attached a screenshot of Visual Studio (2010) showing the ill-rendered controls in the designer; the source (showing the correct version of the controls in the Register Assembly); and the references (right side of screen) with the version number that matches the register assembly in the source).
There is a tooltip when I hover over the <ig:WebDataTree... control that states the following:
The base class includes the field "WebdataTree1", but its type (Infragistics.Web.UI.NavicationControls.WebDataTree) is not compatible with the type of control (Infragistics.Web.UI.NavigationControls.WebDataTree).
Some assistance with this would be very much appreciated!
