I'm trying to hide a Column of Specific Row , not for other Row.
ABhishek
Hello,Please let me know if you need further assistance with this issue.
Hello Abhishek,What you are describing is not a supported scenario. Cell merging is not a supported issue in WDG or WHDG. The best option for you is to hide column as already described. If you want to see this option in our controls please feel free to request it on the following link - http://devcenter.infragistics.com/Protected/RequestFeature.aspx
Hi Nikifor,
Thanks for your help and time, I'm able to hide the column of Specific Row.
But my requirement was to hide the Column of the current selected row and to keep on row.item[1] visble and to merge it across the grid of that specific row.
Abhishek
Hello Abhishek,As far as I understand your goals when a row is selected according to some conditions a column have to be hidden or shown. It is easy to be done on the event RowSelectionChanged on the client. Here is a template of the javascript event:function WebDataGrid1_Selection_RowSelectionChanged(sender, eventArgs)
if (sender._behaviors._selection.get_selectedRows().getItem(0)._index % 2 == 0)
sender._columns.get_column(2).set_hidden(true);
else
sender._columns.get_column(2).set_hidden(false);
