150
Wrapping in Column Headers on exported grid
I am having some problems getting the column headers on an exported UltraWebGrid to be multiple lines high and wrap as needed.
Here is what I am doing:
I have multiple data tables of data to be exported onto one worksheet. To accomplish hits, I first create a new Workbook and Worksheet object. Then, for each data table, I am binding the data table to an UltraWebGrid that is on the form and is set to auto generate columns. I then call the Export method of an UltraWebGridExcelExporter specifying a row for it to export to as well as the grid to export and the sheet that I created earlier. I then repeat this process using the same grid for each data table.  Once all of the data tables have been exported, I stream the Excel workbook out to the browser using the Save method of the Workbook, passing it the Page’s OutputStream. Other than the header heights, this is working beautifully.
A few other things that I am doing, in case it matters, are:
  • I am setting the column width of each Column in the Worksheet to a defined width. This is done after all of the data tables have been exported to keep the auto-sizing routines with the exporter or grid from overriding my defined widths.
  • I am using the DataBound event of the grid to set the colors of specific cells based on their column and value.
Things I have tried:
  • setting the header size in the grid tag on the .ascx page using
    <HeaderStyleDefault  Height="64" Wrap="true" Font-Bold="true">
  • using the HeaderRowExporting event of the grid and setting
    e.Band.HeaderStyle.Wrap = true and e.Band.HeaderStyle.Height = 64
  • Setting the style of the header from the Grids DataBound event via the col.Header.Style.Height and col.Header.Style.Wrap properties of each column in the grid.
How can I get the header cells in the exported file to be taller and to word wrap?
Glenn
  • 150
    Verified Answer
    Ok, I did finally get this to work, just not as "cleanly" as I had hoped. After I call the Export command of the UltraWebGridExcelExporter, I run the following lines:
    sheet.Rows[currentRow].Height = 602;
    sheet.Rows[currentRow].CellFormat.WrapText = ExcelDefaultableBoolean.True;
    This sets the height and wrapping of the curent row, which is where I exported to, so it is the "header" row. Remember that Excel sets the height in Twips, so that is 602 twips, or about a value of 30 as seen in Excel.
    Hope this helps someone...
    Glenn
