Hi, I have a WebTab with two tabs , i used the Load on Demand option , when i set it to "True" , my first tab content was not charged ( i have a grid empty) , it was only chared when i clique on the second tab and i return to clique on the first tab , How can i fix this probleme ?
Hi bouhmid86,
I am following up to check if you are still experiencing any issues. Please feel free to contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
If I am understanding correctly, the grid in your first tab is not being loaded on the first load. I tested this scenario but am so far unable to replicate your issue using version 11.1 under Mozillza 7 and IE9. Attached is the sample I used.
In order to be able to further investigate the matter, please provide me with your product version. A sample illustrating the issue would be greatly appreciated.
Please contact me if you have any questions.
