I am using the autocomplete feature of the webdropdown. It works well with a SqlDataSource, however when I bind it to a webservice, the page loads up well. But as I type in the textbox, I get an error which reads
Async request failed
[Exception]: RowFilter is incorrect. at Infragistics.Web.UI.Framework.Data.FilterRecord.ParseRowFilter(String rowFilter)... so on
In the Page_Load of my code behind, I have:
Dim getCities As New GetCities
WebDropDown3.DataSource = getCities.GetCities2()
WebDropDown3.TextField = "cty_name"
WebDropDown3.EnableAutoFiltering = ListControls.AutoFiltering.Server
WebDropDown3.EnableLoadOnDemand = True
Web Service Code
<WebMethod()>
Public Function GetCities2() As String()
Dim term As String = Context.Request.QueryString("term")
Dim cities As New Generic.List(Of String)
Dim constring As String = "Data Source=(local); Initial Catalog=rereE;User Id=eer;Password=ddd"
Dim con As New SqlConnection(constring)
Dim js As New System.Web.Script.Serialization.JavaScriptSerializer
Try
con.Open()
Dim sql As String = "SELECT cty_name,cty_code,cty_zip from city"
Dim adpter As SqlDataAdapter = New SqlDataAdapter(sql, con)
Dim ds As DataSet = New DataSet("cities")
adpter.Fill(ds)
For Each dr As DataRow In ds.Tables(0).Rows
cities.Add(dr("cty_name").ToString)
Next
con.Close()
Catch ex As Exception
Context.Response.Write("Error:" + ex.Message)
End Try
Return cities.ToArray
Can some one tell me what is it that I am doing Wrong?.
Pradeep
http://ko.infragistics.com/community/forums/p/86636/432069.aspx#432069
Can you please assist on my issue as it is very simular?
Hi Pradeep,
It has been some time since your post, however in case you still need assistance I would be glad to help.
In this scenario, in order to make use of the autofiltering features of WebDropDown I would suggest that you modify your service's webmethod - GetCities, to return a DataTable or DataSet (which in your case is already available - ds) and use them as the datasource for your dropdown.
Please feel free to contact me if you have any questions.
