430
Problem with WHDG
Hi everyone,
This is my first time that I work with the WHDG. So I would like to bind my WHDG to xml.
I realize the first step "Loading the "title" tag in the table, but when I click into the arrow to display the sub items, an error will appear saying:
Key:Category must be unique. The field objects in the grid must have non-empty unique keys assigned to the Key property.
this is My XML File:
<?xml version="1.0" encoding="utf-8"?>
<ItemList>
<Item><Category>1- category 1</Category><Title>title 11</Title><Key>A1</Key></Item>
<Item><Category>1- category 1</Category><Title>title 12</Title><Key>A2</Key></Item>
<Item><Category>1- category 1</Category><Title>title 13</Title><Key>A3</Key></Item>
<Item><Category>1- category 1</Category><Title>title 14</Title><Key>A4</Key></Item>
<Item><Category>2- category 2</Category><Title>title 21</Title><Key>A5</Key></Item>
<Item><Category>2- category 2</Category><Title>title 22</Title><Key>A6</Key></Item>
<Item><Category>2- category 2</Category><Title>title 23</Title><Key>A7</Key></Item>
<Item><Category>2- category 2</Category><Title>title 24</Title><Key>A8</Key></Item>
<Item><Category>3- category 3</Category><Title>title 31</Title><Key>A9</Key></Item>
<Item><Category>3- category 3</Category><Title>title 32</Title><Key>A10</Key></Item>
<Item><Category>3- category 3</Category><Title>title 33</Title><Key>A11</Key></Item>
<Item><Category>4- category 4</Category><Title>title 41</Title><Key>A12</Key></Item>
<Item><Category>4- category 4</Category><Title>title 42</Title><Key>A13</Key></Item>
<Item><Category>4- category 4</Category><Title>title 43</Title><Key>A14</Key></Item>
<Item><Category>4- category 4</Category><Title>title 44</Title><Key>A15</Key></Item>
<Item><Category>4- category 4</Category><Title>title 45</Title><Key>A16</Key></Item>
<Item><Category>4- category 4</Category><Title>title 46</Title><Key>A17</Key></Item>
</ItemList>
this my code ASP
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server">
    <div>
    <asp:ScriptManager ID="ScriptManager1" runat="server">
        </asp:ScriptManager>
    <center>
    <h1>Infragistics WebHierarchicalDataGrid bound to on-the-fly grouped data</h1>
    <h2>Uses on-demand loading of child records</h2>
        <ig:WebHierarchicalDataGrid id="WebHierarchicalDataGrid1" runat="server"
           Width="800px" AutoGenerateBands="False" AutoGenerateColumns="False"
            EnableAjax="False">
        </ig:WebHierarchicalDataGrid>
    </center>
    </div>
    </form>
</body>
</html>
and finally here is my C# Code
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Data;
using System.Data.OleDb;
using Infragistics.Web.UI.GridControls;
namespace HierarchicalGrid
    public partial class _Default : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
            if (!Page.IsPostBack)
                DataSet dsModele = new DataSet();
                dsModele.ReadXml(@"C:\ModeleFR.pmml");
                dsModele.Tables[0].TableName = "Model";
                DataView dv = dsModele.Tables["Model"].DefaultView;
                dv.Sort = "Category ASC";
                dsModele.Tables.Add(dv.ToTable("Categories", true, "Category"));
                DataRelation rel = new DataRelation("CategoryModel",
                    dsModele.Tables["Categories"].Columns["Category"],
                    dsModele.Tables["Model"].Columns["Category"]);
                dsModele.Relations.Add(rel);
                dsModele.Tables["Categories"].PrimaryKey = new DataColumn[] {
                    dsModele.Tables["Categories"].Columns["Category"] };
                this.Session["CategoryModel"] = dsModele;
            DataSet ds = this.Session["CategoryModel"] as DataSet;
            BoundDataField boundField = new BoundDataField(true);
            boundField.Key = "Category";
            boundField.Header.Text = "Category";
            boundField.DataFieldName = "Category";
            this.WebHierarchicalDataGrid1.Columns.Add(boundField);
            Band childBand = new Band();
            childBand.DataKeyFields = "Title";
            childBand.Key = "Categories1";
            childBand.DataMember = "Categories";
            this.WebHierarchicalDataGrid1.Bands.Add(childBand);
            boundField.Key = "Title";
            boundField.Header.Text = "Title";
            boundField.DataFieldName = "Title";
            this.WebHierarchicalDataGrid1.Bands["Categories1"].Columns.Add(boundField);
            this.WebHierarchicalDataGrid1.DataSource = ds;
            this.WebHierarchicalDataGrid1.DataMember = "Categories";
            this.WebHierarchicalDataGrid1.DataKeyFields = "Category";
            this.WebHierarchicalDataGrid1.DataBind();
Anyone can help me please
THANK YOU
