I have a requirement to hide/show a row island on a WHDG. I have tried handling the InitializeRow event on Server side and then applying smtg like: e.Row.CssClass = "styleCell"; which works well when we are dealing with a single parent row. however, when the parent is bounded to a child row, the style does not take effect; and I have applied it to both parent and child rows.
Thanks for your help!
javier
how did you hide the row island on the server side?
I implemented as you described and now it works fine.
THnaks
Hi Javier,
Please feel free to contact me if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
In order for the row styling CSS class to be applied it needs to be defined using selectors as such:
tbody.igg_Item>tr.rowStyle>td{ background-color:Green !important;}
Then, in InitializeRow you can use:
e.Row.CssClass = "rowStyle"
A detailed guide on styling the WebDataGrid can be found at:
http://forums.infragistics.com/blogs/engineering/archive/2010/08/25/webdatagrid-css-styling-guide.aspx
Please contact me if you have any questions.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
