I have a V10.2 UltraWebGrid on my page. One column is type DropDownList and displays a dynamic list of company employees. My problem is that the grid displays many columns, so column width is at a premium. When I move the cursor over a selection on the personnel drop-down list, it highlights the selection; however, for longer names, the name is truncated and the user cannot read the entire name. Consequently, if I have two employees named "Hammerschmidt, John" and "Hammerschmidt, Joan", the user cannot determine which employee to select because he only sees "Hammerschmi". Is there a way to either provide a tooltip when the cursor is placed over a drop-down name or display the full name in the tray at the bottom of the page (preferable)?
Hi
I have a dropdownlist column in ultrawingrid, When i mouse over on the dropdown list items cursor should be hand cursor.
How to make it? I tried aftercelllistcloseup event also but it didnt work....
Please help as soon as possible
Hi megryan,
Please do not hesitate to contact me if I can be of further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Okay. Thanks for the response.
I have investigated your case and there seems to be no obvious way to access the on hover value of a dropdownlist column. However, you may be able to use a templated column with a DropDownList inside it to handle the OnMouseOver event of the dropdown.
Please note that this would work when hovering on options only in Mozilla. In IE, the OnMouseOver handler will be fired after selecting a new value and hovering on the dropdown.
Here is some sample code for setting the value of the item on which the cursor is over as the text of a label:
function mouseOverHandler(sender, e) {var a = (!e.target ? event.srcElement.value : e.target.value);document.getElementById("Label2").innerHTML = a.toString();}
<asp:DropDownList ID="DropDownList1" runat="server" onmouseover ="mouseOverHandler(this,event)"><asp:ListItem >1</asp:ListItem><asp:ListItem>2</asp:ListItem><asp:ListItem>3</asp:ListItem></asp:DropDownList>
Please do not hesitate to contact me if you need further assistance.
