745
FooterTemplate problem
I have this webdatagrid, with a column "Estado". I applied a footer that contains a template.
In the code behind, after the databinding, if I try to access the button inside my FooterTemplate:
CType(wdgVendasVendedor.Columns.Item("Estado").Footer.FindControl("lbtnEstadoFooter"), Button).CssClass = "CmdDash"
It gives me an exception, because FindControl returns "Nothing".
How can I access the button inside my FooterTemplate at runtime?
Below is the gatagrid. Thank you.
ig:WebDataGrid ID="webDataGrid1" runat="server" AutoGenerateColumns="False" Width="100%" Height="200px" ShowFooter="True" EnableDataViewState="True" Visible="False">
   <Columns>
<ig:TemplateDataField Key="Estado" Width="16px" Header-Text="" Header-Tooltip="Alerta sobre o Desvio de Vendas">
<ItemTemplate>
<asp:Button ID="lbtnEstado" runat="server" Height="16px"></asp:Button>
</ItemTemplate>
<FooterTemplate>
<asp:Button ID="lbtnEstadoFooter" runat="server" Height="16px" CssClass="CmdVerdeDash"></asp:Button>
           </FooterTemplate>
</ig:TemplateDataField>
Columns>
<Behaviors>
<ig:Selection RowSelectType="Single" Enabled="True" CellClickAction="Row"></ig:Selection>
<ig:ColumnResizing Enabled="false"></ig:ColumnResizing>
<ig:Filtering Alignment="Top" Visibility="Visible" Enabled="true" AnimationEnabled="false" />
</Behaviors>
</ig:WebDataGrid>
