Hi All
In my project, there is a requirement to generate WebTabs dynamically as the number of tabs can be different for diff users. I'm testing this thing and having an issue. When I add WebTab in aspx file (using ig:WebTab), it works very fine but when I generate WebTabs through C# code, nothing appears in my browser. On viewing the Page Source, I found that WebTab is generated with style element visibility: hidden. I manually changed it through Firebug but now I'm unable to change the tabs. Nothing really happens when I click on some other tab. I can view the content of only 1 tab which is enabled. I beleieve both of these problems are interlinked and I'm missing something in code. Please find below the code I'm using to generate WebTab:
protected void Page_Load(object sender, EventArgs e) { Infragistics.Web.UI.LayoutControls.WebTab tab = new Infragistics.Web.UI.LayoutControls.WebTab(); // Tab container tab.Enabled = true; tab.EnableActivation = true; Infragistics.Web.UI.LayoutControls.ContentTabItem cti1 = new Infragistics.Web.UI.LayoutControls.ContentTabItem(); // Child tabs cti1.Text = "Tab 1"; cti1.Enabled = true; tab.Tabs.Add(cti1); Infragistics.Web.UI.LayoutControls.ContentTabItem cti2 = new Infragistics.Web.UI.LayoutControls.ContentTabItem(); // Child tabs cti2.Text = "Tab 2"; cti2.Enabled = true; tab.Tabs.Add(cti2); MainContent.Controls.Add(tab); }
I'm doing this in my Master page (Site.Master.cs) as I want the menu to be available throughout the site.
So basically 2 problems are there:
- WebTabs not getting displayed in browser (hidden through css property generated during rendering)
- When forcefully enabled, cannot be used
Any help will be appreciated.
Thanx
I have the same problem.
Did you resolved it?
Hi sirshanam,
Please let me know if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
I have investigated your scenario but am so far unable to replicate the behavior with the latest service release for 11.1 (2064) in IE9 and Mozilla 7. In order to continue researching the matter I would need to know your product version.
