65
Databind Error not throwing an exception
Greetings,
I am debugging a databind issue with WebDataGrid using Infragistics35.Web.v11.1, Version=11.1.20111.1006.
The problem was tracked down to a record with bad data in a field. It had ASCII 0 (not null but a length 1 string) in a Field that should be "Y" or "N".  We are not doing anything other than displaying data in this grid.  Even when we tested by having a button set the datasource and do the databind, we were not able to catch this error.  The application gave an asp.net error occured web page with a non-descript error.  The code below never threw an exception when binding the data, were the exception occurs.  It took hard trial and error to determine what field and then what record was causing this issue.
What is the right way catch this exception as not to crash this appliction?
RBB
Protected Sub Button1_Click(sender As Object, e As EventArgs) Handles
Button1.Click
Try
WebDataGrid1.DataSource = SqlDataSource1
WebDataGrid1.DataBind()
Catch ex As Exception
MsgBox(ex.Message.ToString,
MsgBoxStyle.MsgBoxSetForeground, "Binding")
End Try
End Sub
