I am trying to use WebDatamenu in Asp.net application. But I have failed to apply a style "RedPlanet" to webDatamenu control. Please brief me in deatil steps to apply the Style to webDatamenu control.
Even the how the images will be bind to perticualr control.
Please brief me with some simple sample will be appreciable.
I have tried Online sample it looks like simply you made it Complex.
Anil kumar
Hello Anil,
Thank you for the update.
You do not need all the files from the ig_res/RedPlanet folder
You can exclude all the files which you will not use and leave only these corresponding for the WebDataMenu
Also there is a StyleSetPath property which you can use in order to set different directory.
Please refer to the below forum thread discussing similar topic
http://community.infragistics.com/forums/p/30696/271217.aspx
http://forums.infragistics.com/blogs/engineering/archive/2010/08/10/which-are-my-css-files.aspx
Let me know if you need further assistance
I successfully able to Apply the theme. But My concern was the steps.
Like i have to include the Themes folder "Igres". It includes all the controls but I want only the webdatamenu. So I was expecting some answer from you. Now I am using only webdatamenu but i have included the complete "igres" theme folder. Which is not correct.
Thank You
Anil Kumar
Hello akhanil ,
Thank you f or posting in our forums.
You should be able to apply RedPlanet style using the Properties window in Visual Studio
Choose StyleSetName and Import RedPlane style library.
I was able to achieve this using the latest service release of version 11.1
11.1.20111.2064
Please let me know if this helps.
I have applied the StyleSetName to "RedPlanet" but it is not working. So I want the necessary files and changes required to apply the Style. Could you please brief me.
Please if you describe with sample will be greatly appreciated.
Code Snippet :-
<html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title></title> <link href="Styling/sampleWebDataMenu.css" rel="stylesheet" type="text/css" /> <link href="../ControlPanel/ControlPanel.css" rel="stylesheet" type="text/css" /> <script src="../ControlPanel/ControlPanel.js" type="text/javascript"></script></head><body> <form id="form1" runat="server"> <asp:ScriptManager ID="ScriptManager1" runat="server"> </asp:ScriptManager> <div> <%-- <ig:webdatamenu runat="server" id ="mdMenu" ></ig:webdatamenu>--%> <ig:WebDataMenu ID="WebDataMenuSample" runat="server" DataSourceID="MenuDataSource" MaxDataBindDepth="1" Width="100%" StyleSetName="RedPlanet"> <GroupSettings Orientation="Horizontal" /> <DataBindings> <ig:DataMenuItemBinding DefaultText=" " TextField="Text" ValueField="Value" ImageUrlField="ImageUrl" NavigateUrlFields="URL" TargetField="_blank" ToolTipField="Text" /> </DataBindings> </ig:WebDataMenu> <asp:XmlDataSource runat="server" ID="MenuDataSource" XPath="/MenuData/CommunitySiteMenu/Menu" DataFile="~/App_Data/MenuData.xml" /> </div> </form></body></html>
use
StyleSetName="Default" , such as Office2007Blue,Office2007Black,IG ....
