ExternalException (0x80004005): A generic error occurred in GDI+.] System.Drawing.Image.Save(String filename, ImageCodecInfo encoder, EncoderParameters encoderParams) +377630 System.Drawing.Image.Save(String filename, ImageFormat format) +69 Infragistics.WebUI.UltraWebChart.UltraChart.Render(HtmlTextWriter output) +10829[ImageStoreException: Unable to write chart image files at given file path. Please check and correct UltraChart's DeploymentScenario property. Or please provide write permissions to directory path where chart must save images. Please refer Deployment Scenario section in help files. -Or- Follow KB article link: http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=5444 ]Infragistics.WebUI.UltraWebChart.UltraChart.Render(HtmlTextWriter output) +10970 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +134 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +134 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +134 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +134 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19 System.Web.UI.UpdatePanel.RenderChildren(HtmlTextWriter writer) +234 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.UpdatePanel.Render(HtmlTextWriter writer) +34
Any idea pls ??
I've tried on Windows Server 2003, but the problem can not be resolved.
Hi, looks like giving the full control permission to aspnet/networkservices on the chart images/charts folder solves the issue.
