I have webdatagrid, I want to set the border right of some of the headers, not all. Let s say my webgrid has 9 columns, i want to set border-width and color of only 3 of the columns.
I manage to set the border of the columns themselves by setting:
<ig:BoundDataField DataFieldName="NPFACTOR" Key="NpFactor" Width="50px"
DataFormatString="{0:F2}" CssClass="FatSeperatorRight RightCellContent">
<Header Text="Indice np" CssClass="FatSeperatorRight" />
</ig:BoundDataField>
But that does not cover the header, as you can see from my screen shot attached. And the CssClass="SeperatorRight" in the <Header tag does not seem to affect the column's header of the column in question.
Any suggestions pls ??
Thank u :)
Hi rtutus,
Please let me know if you require more help.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Can you try using one class named .iggHeader for one of your columns and another class named for instance .igg_Header2 (could be anything) for another column header.
Please let me know if this helps.
Hi Petar, thanks a lot for the answer, very good one. What if we want to have to different styles applicable for 2 sets of columns. I want one style let s say with separator width 5px applyed to some columns and want another style with border width: 2 px that i can apply to other columns ? what should I call the 2 different styles so that I call them differntly depending of the column of interest.
I can't just call them both:
.igg_Header
color: Black;
border-right: 5px solid Black;
u know what I mean ??
Gracias senior :)
Please let me know if you need further assistance.
The styling of WebDataGrid's headers is applied by the .igg_Header CSS class. Therefore, in order to apply custom header borders for some of your columns you need to define a class:
.igg_Header {border-right: solid 5px Black;}
and apply it as the CSS class for your desired column(s).
You can find detailed information on styling the WebDataGrid using CSS at:
http://forums.infragistics.com/blogs/engineering/archive/2010/08/25/webdatagrid-css-styling-guide.aspx
