10240
determining a read-only field in js
How can I check to see if a field of the WebDataGrid is read-only field?
  • 10240
    One way to do this is the handle the WDG ActiveCellChanged client-side event. This js function is an example of how you can check to see if a field of the grid is set as Read-Only:
    var colkey = eventArgs.getActiveCell().get_column().get_key();
    var i sender.get_behaviors().get_editingCore().get_behaviors().get_cellEditing().get_columnSettings()._items.length;
                debugger;
                for (var k = 0; k
                    if (sender.get_behaviors().get_editingCore().get_behaviors().get_cellEditing().get_columnSettings()._items[k]._readOnly == true) {
                        if (sender.get_behaviors().get_editingCore().get_behaviors().get_cellEditing().get_columnSettings()._items[k]._address == colkey) {
                            alert(eventArgs.getActiveCell().get_column().get_key());
    Let me know if you need any additional assistance regarding this matter.
