4110
UltraWebGrid date formatting issue
I have an Ultrawebgrid that is loaded dynamically once when the page first loads, via sql dataset from a MSSQL2005 database. I am using the NET3.5, 10.3.20103.2134 version of the control(please do not suggest upgrade, as this is not an option). I have set the formatting in the InitializeLayout method and until recently the date has formatted just fine. Now, this grid, out of 15 total grids on the page, won't format the date. Except for one column name, all the grids are the same. I have included all the code below. I know we had 1 or 2 MS security udpates recently, but I would think that would effect all my grids, not just the one and I am having no luck tracking down the problem. I can't provide a data sample, but all the raw records have a proper sql date format of yyyy-mm-dd hh:mm:ss that I am formatting to MM/dd/yyyy. Thanks for any help you can provide.
Try
ds = GetDataSet("loadMYDATA", Profile)
If Not IsDatasetValid(ds) Then
ds = GetDataSet("emptyMYDATA")
m_MYDATACount = 0
Else
lblMYDATACount.Text = ds.Tables(0).Rows.Count
m_MYDATACount = ds.Tables(0).Rows.Count
End If
igMYDATA.DataSource = ds
igMYDATA.DataBind()
Catch ex As Exception
End Try
Protected Sub igMYDATA_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles igMYDATA.InitializeLayout
With e.Layout.Bands(0).Columns.FromKey("ID")
.Header.Style.HorizontalAlign = HorizontalAlign.Center
.CellStyle.HorizontalAlign = HorizontalAlign.Center
.Hidden = True
End With
With e.Layout.Bands(0).Columns.FromKey("PROCESS")
.Header.Caption = "Process"
.Header.Style.HorizontalAlign = HorizontalAlign.Left
.CellStyle.HorizontalAlign = HorizontalAlign.Left
End With
With e.Layout.Bands(0).Columns.FromKey("MYDATA_NUMBER")
.Header.Caption = "MYDATA Number"
End With
With e.Layout.Bands(0).Columns.FromKey("ASSIGNED_OFFICE")
.Header.Caption = "Assigned To"
End With
With e.Layout.Bands(0).Columns.FromKey("DAYS_OPEN")
.Header.Caption = "Days Open"
End With
With e.Layout.Bands(0).Columns.FromKey("DUE_DATE")
.Header.Caption = "Due Date"
.Format = "MM/dd/yyyy"
End With
With e.Layout.Bands(0).Columns.FromKey("TYPE")
.Hidden = True
End With
With e.Layout.Bands(0).Columns.FromKey("INITIATION_DATE")
.Header.Caption = "Initiation Date"
.Hidden = True
End With
End Sub
<igtbl:UltraWebGrid ID="igMYDATA" runat="server" DisplayLayout-AutoGenerateColumns="true"
EnableAppStyling="True" StyleSetName="Office2007Blue" StyleSetPath="~/ig_res/"
DisplayLayout-CellPaddingDefault="5" DisplayLayout-Pager-AllowPaging="true" DisplayLayout-Pager-PageSize="100"
DisplayLayout-Pager-PagerAppearance="Both" Height="350px" Width="100%" DisplayLayout-AllowSortingDefault="Yes">
<Bands>
<igtbl:UltraGridBand>
<AddNewRow View="NotSet" Visible="NotSet">
</AddNewRow>
</igtbl:UltraGridBand>
</Bands>
<DisplayLayout BorderCollapseDefault="Separate" CellPaddingDefault="5" Name="igMYDATA"
RowHeightDefault="20px" Version="4.00" HeaderClickActionDefault="SortSingle">
<FrameStyle>
</FrameStyle>
<Pager Alignment="Left" AllowPaging="True" PagerAppearance="Both" PageSize="100"
QuickPages="3" StyleMode="Numeric" MinimumPagesForDisplay="2">
<PagerStyle HorizontalAlign="Left" VerticalAlign="Middle" />
<ComboStyle HorizontalAlign="Left" VerticalAlign="Middle">
</ComboStyle>
</Pager>
<ActivationObject BorderColor="" BorderWidth="">
</ActivationObject>
</DisplayLayout>
</igtbl:UltraWebGrid>
