95
Trying to load xls
   got a problem. I'm loading xls documents with function Workbook.Load(). Then i load simple document it works good, but when i load a document with dropdown, radiobutton objects ... i got an exception. Stack trace:
  System.ArgumentException was unhandled by user code
  Message="Only the DontMoveOrSizeWithCells ShapePositioningMode can be applied to a comment shape.\r\nParameter name: value"
  Source="Infragistics2.Excel.v7.3"
  ParamName="value"
  StackTrace:
       at Infragistics.Excel.WorksheetCellCommentShape.VerifyPositioningMode(ShapePositioningMode value)
       at Infragistics.Excel.WorksheetShape.SetPositioningMode(ShapePositioningMode value, Boolean verifyIsDefined)
       at Infragistics.Excel.Serialization.EscherRecords.ClientAnchor.Load(WorkbookSerializationManager manager)
       at Infragistics.Excel.Serialization.EscherRecords.EscherRecordBase.LoadRecord(WorkbookSerializationManager manager)
       at Infragistics.Excel.Serialization.EscherRecords.EscherRecordContainerBase.Load(WorkbookSerializationManager manager)
       at Infragistics.Excel.Serialization.EscherRecords.ShapeContainer.Load(WorkbookSerializationManager manager)
       at Infragistics.Excel.Serialization.EscherRecords.GroupContainer.Load(WorkbookSerializationManager manager)
       at Infragistics.Excel.Serialization.BiffRecords.MSODRAWINGRecord.Load(WorkbookSerializationManager manager)
       at Infragistics.Excel.Serialization.WorkbookSerializationManager.LoadCurrentRecord()
       at Infragistics.Excel.Serialization.WorkbookSerializationManager.Load()
       at Infragistics.Excel.Workbook.LoadHelper(Stream stream, String parameterName)
       at Infragistics.Excel.Workbook.Load(String fileName)
       at Testinis.test.MakeXls(Object sender, EventArgs e) in C:\Documents and Settings\mrudys\My Documents\Visual Studio 2005\Projects\Testinis\Testinis\test.aspx.cs:line 44
       at Testinis.test.ButtonClick(Object sender, EventArgs e) in C:\Documents and Settings\mrudys\My Documents\Visual Studio 2005\Projects\Testinis\Testinis\test.aspx.cs:line 68
       at System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e)
       at System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument)
       at System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument)
       at System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument)
       at System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData)
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
In document for all format controls properties i set don't move or size with cells, but i still get an error. May it's impossible to read more complicated document? Maybe somethere are requerements to loading format?
Parents Reply Children
No Data
