I have a page that generates a chart and grid. I am trying to export the 2 controls to the same pdf file. I tryed to build on the illustration in:
http://help.infragistics.com/Help/NetAdvantage/NET/2007.3/CLR2.0/html/Chart_Exporting_Numerous_Charts_to_a_PDF.html
I added a grid to the page but it is not showing.
I removed the chart from the code the kept the grid then it showed.
I feel that a small thing is missing but I am lost. Any ideas?
bpconsiltancy -
Thank you for posting the solution.
Patrick
This is an online conversion tool.
http://www.carlosag.net/Tools/CodeTranslator/Default.aspx
Just past the code there and it will be directly converted. Becareful as it is not 100% perfect. Sometimes you have to do some minor changes. Tell me if you faced any problems.
Hi,Do you have the code in C#.
I managed to do it using 'bands'. If any one is interested in the code, here it is (the grid is filled from a datatable, I didn't use the grid exporter):
Dim dt As datatable = Infragistics.UltraChart.Data.DemoTable.Table(4) Me.UltraWebGrid1.DataSource = dt Me.UltraWebGrid1.DataBind() Dim numColumns As Integer = dt.Columns.Count Dim numRows As Integer = dt.Rows.Count Dim reportPath As String = _ System.Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) Dim report As New Report() Dim section1 As Infragistics.Documents.Report.Section.ISection = report.AddSection 'Dim page As Section.ISectionPage = section1.AddPage section1.PagePaddings = New Infragistics.Documents.Report.Paddings(50) '------Section Header----------------------- Dim sectionHeader As Infragistics.Documents.Report.Section.ISectionHeader = section1.AddHeader() sectionHeader.Repeat = True sectionHeader.Height = 50 Dim sectionHeaderText As Infragistics.Documents.Report.Text.IText = sectionHeader.AddText(0, 0) sectionHeaderText.Paddings.All = 10 sectionHeaderText.Alignment = _ New TextAlignment(Alignment.Left, Alignment.Middle) sectionHeaderText.Height = New RelativeHeight(100) sectionHeaderText.AddContent("Sample") '------------------------- '----page numbering------------- Dim pn As Infragistics.Documents.Report.Section.PageNumbering = section1.PageNumbering pn.Style = New Infragistics.Documents.Report.Text.Style(Fonts.Arial, Infragistics.Documents.Graphics.Brushes.Black) pn.Template = "Page [Page #] of [TotalPages]" pn.SkipFirst = False pn.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Right pn.Alignment.Vertical = Infragistics.Documents.Report.Alignment.Bottom pn.OffsetY = -18 '--------------- Dim band1 As Infragistics.Documents.Report.Band.IBand = section1.AddBand Dim band2 As Infragistics.Documents.Report.Band.IBand = section1.AddBand band1.Paddings = New Infragistics.Documents.Report.Paddings(50) '--------------band1---------------- Dim canvas As ICanvas = band1.AddCanvas canvas.Width = New FixedWidth(400) canvas.Height = New FixedHeight(300) Dim g As System.Drawing.Graphics = canvas.CreateGraphics() UltraChart1.ChartType = ChartType.GanttChart UltraChart1.Data.SwapRowsAndColumns = False UltraChart1.Data.DataSource = dt UltraChart1.Data.DataBind() UltraChart1.RenderPdfFriendlyGraphics(g) '-----------end band1--------------- '---------------band2'-------------- Dim gridPattern As New Infragistics.Documents.Report.Grid.GridPattern() gridPattern.Borders = New Borders(New Infragistics.Documents.Graphics.Pen(New Infragistics.Documents.Graphics.Color(0, 0, 0)), 5) gridPattern.Background = New Background(Infragistics.Documents.Graphics.Brushes.White) ' Create a new pattern for each cell. Dim cellPattern As New Infragistics.Documents.Report.Grid.GridCellPattern() cellPattern.Paddings = New Paddings(5, 10) cellPattern.Borders = New Borders(New Infragistics.Documents.Graphics.Pen(New Infragistics.Documents.Graphics.Color(0, 0, 0))) 'cellPattern.Background = new Background(brush3); cellPattern.Alignment = _ New Infragistics.Documents.Report.ContentAlignment(Alignment.Center, Alignment.Middle) Dim grid As Infragistics.Documents.Report.Grid.IGrid = band2.AddGrid grid.ApplyPattern(gridPattern) ' Declare a Column, Row, and Cell object ' for object creation. Dim gridColumn As Infragistics.Documents.Report.Grid.IGridColumn Dim gridRow As Infragistics.Documents.Report.Grid.IGridRow Dim gridCell As Infragistics.Documents.Report.Grid.IGridCell ' Add columns to the grid. For i As Integer = 0 To numColumns - 1 gridColumn = grid.AddColumn() Next i ' Add a header to the grid. Dim gridHeader As Infragistics.Documents.Report.Grid.IGridHeader = grid.Header Dim headerCell As Infragistics.Documents.Report.Grid.IGridCell Dim headerCellText As Infragistics.Documents.Report.Text.IText For Each dc As DataColumn In dt.Columns headerCell = gridHeader.AddCell cellPattern.Apply(headerCell) headerCell.Background = New Background(Infragistics.Documents.Graphics.Brushes.LightSlateGray) headerCellText = headerCell.AddText headerCellText.Alignment = New TextAlignment(Alignment.Center, Alignment.Middle) headerCellText.AddContent(dc.ColumnName) Next ' Add a footer to the grid. Dim gridFooter As Infragistics.Documents.Report.Grid.IGridFooter = grid.Footer Dim footerCell As Infragistics.Documents.Report.Grid.IGridCell = _ gridFooter.AddCell() footerCell.ColSpan = numColumns cellPattern.Apply(footerCell) Dim gridFooterText As Infragistics.Documents.Report.Text.IText = _ footerCell.AddText() gridFooterText.Alignment = _ New TextAlignment(Alignment.Right, Alignment.Middle) gridFooterText.AddContent("Grid Footer") 'Add rows to the grid
For Each dr As DataRow In dt.Rows gridRow = grid.AddRow() For i As Integer = 0 To numColumns - 1 gridCell = gridRow.AddCell() cellPattern.Apply(gridCell) gridCell.AddQuickText(dr(i).ToString) Next Next '----------------end band2------------------ report.Publish(reportPath + "\Report.pdf", FileFormat.PDF)
