Dear all
I'm new in here I come from china and my english is very bad so maybe you can not understand what I said but I hava some problem SO ......
There is a table like this
now I whant to get this chart the style like this
can anyone help me?give my an example?
thanks a lot.
well thanks
Hello JamesLee1001 ,
If you need further assistance with this don't hesitate to ask.
Here is also a link from our documentation regarding creation of a composite chart that you might find useful:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Chart_Creating_a_Composite_Chart_Using_the_Chart_Wizard_Part_1_of_2.html
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Thank you very much! But the company is using vs2005 and netadvantage2009 So I can not open it, but I can take home to open it.
Hey hey hey ... I hope we can become friends.
Once again thank you!!
The only way to achieve this layout is to create a composite chart with 2 layers each containing a StackColumnChart.
For each of those charts you’ll have to set manually numeric series each series element containing 2 label-value pairs one for the bottom part of the stack chart ( which in your case will be the actual value) and one for the maximum value which will be displayed for the top part of the stack column chart. The label will be the text displayed under the x-axis line.
To specify a skin for your stack chart and specify it’s colors from the Chart designer locate the Color model property. Under Skin locate the PE’s Collection. When you click on the collection you’ll see a button. Clicking on that will open the paint element collection editor in which you may specify the different colors for the chart.
Please refer to the attached sample and let me know if you have any questions.
