WebCalendarView year dropdown and month dropdown work well under IE7 and IE8, but in IE9, when it be clicked, no dropdown show, like disable. who can help me?
Hello Mark,
I created a small sample using WebCalendarView trying to reproduce the issue with the year and month drop down buttons in IE 11. However, on my side everything works as expected and I was able to successfully open the drop downs and select month and year.
Here you will find my sample for your reference. I am using version 20.1.20201.4 of Infragistics controls and latest version for IE 11 browser. Can you please test this sample on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it so that it replicates the behavior and send it back to me for further investigation.
Having a working sample on my side is going to b highly appreciated and will help me find the root cause of the behavior.
Regards,Vasya Kachehsmarova
Now I see the same problem on IE11 while on Edge and Chrome everything looks fine...
override this function, it works for IE9
function ig_cancelEvent(e, type) { if (e == null) if ((e = window.event) == null) return; if (type && e.type != type) return; // if (e.stopPropagation != null) e.stopPropagation(); // if (e.preventDefault != null) e.preventDefault(); e.cancelBubble = true; e.returnValue = false; }
how to show only dropwdowns with out imag in webcalenderview
Hi lijiahe,
Thank you for your reply.
Please contact me if there are any other issues I can help you with.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
