103
How to Remove Hyperlinks while exporting grid cells
I have a webdatagrid and i have a column of type LinkButton that. I have written some code to give URLs to Linkbutton in InitializeRow of event.
Now when i am using WebExcelExporter, i am not able to remove these hyperlinks in the exported Excel. How can i do this without loosing theme and formatting.
Thanks in advance.
  • 103
    I could able to figure out the solution for removing Hyperlinks in the template columns.
    Here is the code which will remove Hyperlinks while downloading into excel.
     protected void urlDownloads_Click(object sender, System.EventArgs e)
                try
                    uwgCostCenterAdmin.Behaviors.Paging.Enabled = false;
                    BindGrid();
                    uwgCostCenterAdmin.Columns[4].Hidden = true;
                    WebExcelExporter1.DownloadName = "CostCenter";
                    this.WebExcelExporter1.Export(uwgCostCenterAdmin);
                    this.WebExcelExporter1.EnableStylesExport = true;
                    uwgCostCenterAdmin.Behaviors.Paging.Enabled = true;
                    BindGrid();
                catch (Exception ex)
                    throw ex;
            private int GetIndex(string text)
                for (int i = uwgCostCenterAdmin.Columns.Count - 1; i >= 0; i--)
                    if (uwgCostCenterAdmin.Columns[i].Header.Text == text)
                        return i;
                return 0;
            protected void WebExcelExporter1_CellExporting(object sender, ExcelCellExportingEventArgs e)
                if (!e.IsHeaderCell && !e.IsFooterCell && !e.IsSummaryCell)
                    int index = GetIndex(System.Convert.ToString(e.Worksheet.Rows[0].Cells[e.CurrentColumnIndex].Value));
                    GridRecordItem item = uwgCostCenterAdmin.Rows[e.CurrentRowIndex - 1].Items[index];
                    if (item.Column.GetType().Name == "TemplateDataField")
                        TemplateDataField field = item.Column as TemplateDataField;
                        HyperLink costcenterLink = item.FindControl("costcenterLink") as HyperLink;
                        if (costcenterLink != null)
                            e.WorksheetCell.Value = costcenterLink.Text;
                            e.Cancel = true;
                    else
                        e.WorksheetCell.Value = item.Text;
                        e.Cancel = true;
    Hope this helps.
