I am getting a "System.NullReferenceException: Object reference not set to an instance of an object." error when trying to load this specific Excel file (XmRChartPIR.xlsm). this excel template has a number of macros, buttons and charts.
I have been able to successfully load other files (.xlsm, .xlt, .xls) that are less complicated. Is there something I can do to load the Excel file I am having problems with?
Code:
Dim FileString As String = "...\Excel\XmRChartPIR.xlsm"
Dim exWB As New
Infragistics.Documents.Excel.Workbook()
exWB = Infragistics.Documents.Excel.Workbook.Load(FileString)
StackTrace:
NullReferenceException: Object reference not set to an instance of an object.]Infragistics.Documents.Excel.Serialization.Excel2007.SharedElements.Drawing.BlipElement.Load(Excel2007WorkbookSerializationManager manager, ExcelXmlElement element, String value, Boolean& isReaderOnNextNode) +539 Infragistics.Documents.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, ExcelXmlDocument document, XmlReader reader, ElementDataCache elementCache, List`1 elementCacheCollection, BeforeLoadElementCallback beforeLoadElementHandler, AfterLoadElementCallback afterLoadElementHandler, Boolean& isReaderOnNextNode) +565 Infragistics.Documents.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, ExcelXmlDocument document, XmlReader reader, ElementDataCache elementCache, List`1 elementCacheCollection, BeforeLoadElementCallback beforeLoadElementHandler, AfterLoadElementCallback afterLoadElementHandler, Boolean& isReaderOnNextNode) +632
The bug fix which added the support for round tripping forms in the Excel 2003 formats was fixed in versions 11.1 and later on 11/10/11 (the bug id is 90733). I don't believe the SR with this fix has been released yet. So when that is released, you can install the SR and it should work. If you find that it doesn't, please let me know.
Thank you for all your quick responses, it is very much appreciated.
We tried using an old Excel 97-2003 Worksheet with buttons in it, and the buttons were missing when that file was loaded as well.
When I loaded and saved out the file again, the chart was present, but the button was not. It looks like round-trip support for buttons and other forms was added for the 2003 formats, but not the 2007 formats. This can probably be fixed as a bug. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
As far as what I meant earlier, I was simply saying that if the buttons are not round-tripped, it should not affect the rest of the data on your workbook or cause any exceptions when saving or loading the workbook. If it does, then this would be another bug.
Is there a type of excel button (form controls, activex controls or other) that is maybe better handled by infragistics?
Here is a simple sheet I am using to test. I can load this workbook and write data to a new sheet, but the Button on sheet 1 disappears. The chart however remains in the new workbook.
In my real application I need those buttons to generate charts. I can load the workbook, and write data to a new sheet, but all of the buttons and charts are missing.
